Username Post: Need help with throttle return        (Topic#359847)
pearljam724
pearljam724
Loc: SW Pennsylvania
Reg: 01-27-14
02-17-20 03:54 PM - Post#2786742
Would someone be so kind to explain and post a picture of where the return spring for the throttle connects that allows the pedal to return up and no throttle input ? My spring is connected to the throttle rod but it popped off the other end. I don’t know where it attaches down beside the driver side of the block somewhere ? It under the exhaust manifold just dangling there.
http://i420.photobucket.com/albums/pp282/pearljam 7...
Edited by pearljam724 on 02-17-20 04:03 PM. Reason for edit: No reason given.
Idaho
Idaho
Loc: Upstate New York
Reg: 03-02-07
02-17-20 04:36 PM - Post#2786751
    In response to pearljam724
If I remember correctly, I hook the lower end of the spring under the edge of the oil pan. I've never had it come off. I also found this photo, a more correct way of doing it. A bracket that hooks to the spring and under the oil pan-
Attachment: imagesC5S6ZJWJ.jpg (11 KB) 31 View(s)
1953 210 Chevy convertible, 1953 210 Chevy Handyman station wagon, 1957 GMC Suburban Carryall.
pearljam724
pearljam724
Reg: 01-27-14
02-17-20 04:53 PM - Post#2786752
    In response to Idaho
You’re the man, Idaho. Thank you, greatly. I don’t think mine has the triangular looking bracket all the way down by the pan. The swivel bracket that slides into the stem attached to block. Is there a bolt on the end ? I can’t quite tell looking at your picture or looking at mine from above. My swivel piece isn’t staying stationary. It’s moving cock eyed, when it swivels. I believe a bolt is backing out. I won’t know until I get under there for a better look.
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
02-17-20 05:09 PM - Post#2786754
The stock configuration was a hook type extension from the pan bolt at the point the spring lined up in a straight down or nearly so position. These were almost always thrown away when the pan was removed. The spring then was just hooked over the edge of the pan. On my 52 I had a stainless hose clamp on the exhaust pipe, it held a small bracket with a hole in it and could be moved up and down the pipe to adjust the tension,but just hooking the end over the edge of the pan works okay.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-17-20 05:24 PM - Post#2786755
They are available and makes for a little more of a positive connection than hooked to the edge of the pan.
LINK:
http://www.oldchevytrucks.com/cart/product.asp?pro...
1951 Fleetline Preservation
pearljam724
pearljam724
Reg: 01-27-14
02-17-20 08:01 PM - Post#2786766
    In response to 2blu52
I think you’re exactly correct. I think mine was hooked the same. But, it popped off. Easy fix, knowing now where it hooked.
pearljam724
pearljam724
Reg: 01-27-14
02-17-20 08:02 PM - Post#2786767
    In response to RAM_51
Thank you
eplantage
Loc: Southern MN
Reg: 03-15-04
02-18-20 05:32 AM - Post#2786780
There should be a groove for an "E" clip on the end of the "stem" screwed into the block. Some had a hole for a cotter pin too.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
pearljam724
pearljam724
Reg: 01-27-14
02-18-20 07:37 AM - Post#2786785
    In response to eplantage
I fixed it
Idaho
Idaho
Reg: 03-02-07
02-18-20 07:55 AM - Post#2786789
Execution time: 2.322 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:05 AM
