Username Post: Manual vs. Power Disk Brakes        (Topic#359825)
cware
Loc: Norman, Ok
Reg: 06-15-12
02-15-20 09:07 PM - Post#2786618
Of all you guys who have converted to disk brakes, did you choose to go with power brakes or manual? Can you also explain why one over the other? Thanks.
1966 Biscayne 2 door
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
02-16-20 07:44 AM - Post#2786629
    In response to cware
For me the answer is real simple. Its the word "Power". The system provides it so you don't have to.
02-16-20 08:52 AM - Post#2786632
I would also recommend power, as disc brakes require more pedal effort, to overcome that without power you need a higher pedal ratio.
cware
Loc: Norman, Ok
Reg: 06-15-12
02-16-20 11:42 AM - Post#2786654
Ok thanks. I assumed as much but I read or saw in som video how some people preferred the feel of manual disks as opposed to power. I’ve ordered my big brake kit from CPP but it doesn’t come with the master cylinder or booster. Are most people using the factory style setup for both? I assume it would be adequate enough.
02-16-20 12:17 PM - Post#2786659
Booster design or capacity depends on available vacuum. The stock design is OK for mild engines, you need around 15-16" of vacuum. Less than that a larger capacity unit or a back up source may be required .
cware
Loc: Norman, Ok
Reg: 06-15-12
02-16-20 12:45 PM - Post#2786661
My car will have a mostly stock 6.0 LS. Would stock design be sufficient? Any guys with LS swaps that can shed some
light on this? What setups did you guys go with?
02-16-20 12:54 PM - Post#2786663
Get a vacuum Gage on it, see what you have at idle after warmed up.
carbking
carbking
Loc: Missouri
Reg: 06-14-03
02-17-20 06:32 PM - Post#2786760
Have never done a conversion.
Have had several vehicles with manual disc brakes (some 4-wheel), and others with power discs.
If given a choice, it is manual hands down. I reserve the right to change this opinion should I celebrate over 120 birthdays.
Jon.
Good carburetion is fuelish hot air!
The most expensive carburetor you will ever buy.....is the incorrect one you attempt to modify!
If you truly believe "one size fits all", trying walking a mile in your spouse's shoes!
cware
Loc: Norman, Ok
Reg: 06-15-12
02-17-20 07:07 PM - Post#2786762
    In response to carbking
Jon.
Can you explain why you feel that way?
carbking
carbking
Loc: Missouri
Reg: 06-14-03
02-17-20 07:38 PM - Post#2786764
Better feel of what is going on, and ultimately better control.
The power booster is a buffer between what is felt and what is happening.
Not saying everyone should feel this way at all, but I really prefer manual brakes. Of course, I also prefer manual steering, manual transmission, and manual choke carburetors. I will admit, that as I have grown older, power steering can be useful in parallel parking.
Jon.
Execution time: 0.131 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:49 AM
