Username Post: 1961 Impala clutch Assembly        (Topic#359821)
emont3
Reg: 01-24-20
02-15-20 03:51 PM - Post#2786592
Hello, Does anyone know what is needed to rebuild a clutch assembly for a 1961 impala? My clutch is squeaky as hell. I'm thinking about taking it out and cleaning it up. I just want to order the parts I will be needed to rebuild the assembly. Also is it pretty straight forward removing the clutch assembly? Thanks for your help!
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-15-20 05:21 PM - Post#2786597
    In response to emont3
Chapter 11 of the Shop Manual should have all the info you need.
Pete
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
02-15-20 05:42 PM - Post#2786600
    In response to japete92
You don't rebuild a clutch. You replace the disc and pressure plate.
Member #51
02-15-20 05:44 PM - Post#2786601
    In response to Tri5man
Correct, plus replace the throwout bearing.
Also, if your profile information was filled in to show your location, we might be able to recommend someone close to you to give you some advice and information.
blkss64
Reg: 07-22-12
02-15-20 07:15 PM - Post#2786608
Hello. In my experience, noises need to be diagnosed first. How does the clutch operate? Does it slip under load? Does it vibrate in use?
The Chevrolets of this era use linkage to activate the clutch mechanism.
It is very common to have dry, worn clutch linkage cause noises. The 1961 Chevy uses a large spring on the clutch pedal linkage under the dash. The linkage needs to be closely inspected for evidence of rust build up at each pivot point. This actually maybe the source of the noise. I am not saying that the clutch cover is not the problem, it is just more common to have the linkage be the cause of the noise. Jon
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-15-20 09:13 PM - Post#2786619
    In response to blkss64
The 1961 clutch pedal linkage is a one year only linkage (62, 63 & 64 are way different ) as was stated above, were the large pull back spring is under the dash attached to two connection parts - that could squeak.
The linkage is installed into & through the under dash brace with plastic sleeves ( 4 as I recall) . These sleeves could be worn out. Look/lay under the dash when someone pushes the clutch to test the sound - see if it’s from under the dash.
I hate the 61 under dash linkage when compared to 62 to 64 linkage which is a much better design.
There are no parts other than the 4 plastic sleeves to buy. None of the 1961 under dash clutch linkage is available anywhere.
Only used original linkage could be purchased as a complete set of pedals with all the linkage attached.
Almost all 1961 used pedal / linkage I see for sale “is not complete” - the sellers must be throwing away the big spring and connection pieces ( they claim the pedals are complete and they aren’t).
I have pictures of a complete under dash 1961 pedals, linkage and under dash brace.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
emont3
Reg: 01-24-20
02-16-20 04:25 PM - Post#2786678
Thank you all for the tips. I really believe it's the spring in the clutch assembly that's making all the noise.
Execution time: 0.295 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:29 AM
