Username Post: Temp Gauge Sending Unit        (Topic#359813)
rawaag
rawaag
Loc: Williamsburg Virginia
Reg: 06-12-09
02-14-20 01:35 PM - Post#2786512
As some of you know I'm in the middle of changing out my old 235 for a upgraded 235. I was planning on using all the old upgrades on to the new engine. Of course nothing is that easy. The new short shaft water pump has the fan hitting the Harmonic Balancer, ordered a 1/2 spacer to hopefully to fix. Today I removed the old Water electric Temp sending unit left a hole of 7/8, I think? The old sending unit, which is mechanical is only 1/2"? They sell adapters for different sizes but haven't found one for a 7/8" to 1/2". Another smaller problem I found is that none of my fittings in the block fit my old pressure gauge, nor do the new fuel pump match up to my hard fuel lines. I'm sure most of you have faced these type of problems when pursuing you passion. Any ideas on the Temp gauge sending unit.
Ralph
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-14-20 01:43 PM - Post#2786513
    In response to rawaag
They sell an adapter for those thermal coupler style gauges. It is 1/2" pipe Male pipe to the straight thread with the seat. A lot of the new style thermal coupler gauges still use the same adapter.
Autometer #2264
rawaag
rawaag
Reg: 06-12-09
02-16-20 01:02 PM - Post#2786665
    In response to cbmkr56
I've seen the adapter I need 7/8" however it only comes with the new gauge. I was hoping to continue to use the one in the 52 car. I might need to buy the new gauge just to get the adapter?
Ralph
Airlifter
Airlifter
Reg: 06-07-15
02-16-20 06:46 PM - Post#2786690
I bought an adapter when I installed the 261. I think I got it from Jim Carter Trucks. I will try to remember to look tomorrow.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
2blu52
"19th Year" Silver Supporting Member
2blu52
Reg: 03-12-02
02-16-20 07:12 PM - Post#2786691
Some where I have a NAPA part number for this adapter I will look tomorrow, I know what information it is in but now I have to find that.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
02-17-20 07:12 AM - Post#2786710
    In response to 2blu52
I've bought just the adapter before, but I can't for the life of me remember the part number or where I got it. Might be Jim Carter, cause I restored two '54 Chevy pickups with mostly Jim Carter parts.
rawaag
rawaag
Reg: 06-12-09
02-17-20 07:23 AM - Post#2786713
Thanks, that's good news to hear. I will give them a try and see if they have it. Thanks again!
Ralph
2blu52
2blu52
Reg: 03-12-02
02-17-20 08:24 AM - Post#2786718
Napa part# is Balkampp701-1542 Weatherhead calls it p/n2025x4.
THOMAS JEFFERSON
Airlifter
Airlifter
Reg: 06-07-15
02-17-20 02:07 PM - Post#2786738
Got mine a Jim Carter Classic Truck parts.
P/N ME275.
Hope this helps.
02-17-20 07:21 PM - Post#2786769
With that number you should be able to get it from NAPA with no shipping.
Execution time: 0.141 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:58 PM
