Username Post: Mystery Engine number        (Topic#359808)
gypsy_ivory
Reg: 01-18-06
02-14-20 11:29 AM - Post#2786493
Hi!
I have a 1955 Chevrolet with a 265 V8 that has some pieces marked as 'Made in Canada'. The engine was bought second hand in the 1990s.The number written on the block is very strange. I wonder if somebody knows if it's legit or made up by someone at some point....
It says:
0005692055GB
or
0005692G55GB
Here is the image
Thank you [image]https://www.flickr.com/photos/186913801@N08/ 49534661663[/image]
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
02-14-20 10:47 PM - Post#2786543
    In response to gypsy_ivory
I looked up the block casting # from the left rear of engine where the bell housing bolts on, if so, NO such number even close. Is the number you sent, the one that's stamped on the right front of block, below the right head?
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
alexmr
Loc: Mexico City
Reg: 09-02-06
02-22-20 11:18 PM - Post#2787096
Your engine is one of the three low compression (that's what GH suffix indicates) versions made of the 265 V8 in 1955 for overseas markets. Your unit probably comes from a 55 Chevrolet assembled in Mexico, perhaps Venezuela. Or one sent already assembled from the US to overseas market.
What you mentioned about a "G" I think should be a "C". It means that this engine was made in Canada. Both canadian plants: McKinnon Industries and Windsor Transmission Plant, used to supply engines (V8s and 6s, respectivly) to Tarrytown Assembly Plant, NY, for those units sent assembled to overseas markets, and to Bloomfield Packing Plant, MI, to be part of the CKD kits sent to foreign assembly plants, like GM Mexico.
I have found original V8 engines on mexican assembled 55-57 units that are painted not in the red we all know, but in the "blue flame" blue of the 6 cyls units.
Hope it helps.
Alex
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-25-20 03:53 PM - Post#2787338
    In response to alexmr
Truck 265 engines were never painted orange but were the blue/gray color of a 6 cylinder engine and did run a lower compression ratio.
Execution time: 0.179 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:00 AM
