Username Post: Check out the new Indy Car .        (Topic#359805)
02-13-20 06:20 PM - Post#2786449
Looks like the future has arrived.
Attachment: racefansdotnet-20200207-161900-1.jpg (97.15 KB) 1 View(s)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-14-20 10:29 AM - Post#2786492
details on the engine or motor and drive train details, brakes etc.
would be very helpful
Member #409
02-14-20 10:47 AM - Post#2786495
Adding the windscreen should be a big safety improvement.
02-14-20 11:01 AM - Post#2786497
    In response to grumpyvette
This is the Chevy configuration from Wiki.
This is built on a Dallara Chassis (Italian)
Engine type: Chevrolet V6 - twin-turbocharged
Capacity: 2,200 cc (134 cu in)
HP rating (speedway / 1.5-mile oval / road-street course): 575 hp / 625 hp / 675 hp
Max RPM: 12000 rpm; 12200 rpm overtake
Weight: 112.5 kg (248 pounds)
Oil system: Dry sump lubrication
Turbocharger: Twin - BorgWarner EFR7163
Turbocharger boost levels (speedway / 1.5-mile oval / road-street course): 1.3 bar / 1.4 bar / 1.5 bar & 1.6 bar
Camshafts: Double overhead camshafts
Valve actuation: Finger follower
Valve springs: Wire type
Cylinder head: 4 valves (titanium) per cylinder
Fuel injection: Hitachi/Bosch 6x direct in-cylinder fuel. Hitachi/Bosch 6x high pressure port injectors
Fuel: Sunoco E85 (85% Ethanol, 15% racing gasoline)
Lubricants: Shell Helix Ultra or Pennzoil Ultra Platinum (Team Penske)/Peak Motor Oil (other Chevrolet-powered teams)
Block & head material: Aluminium
Crankshaft: Billet steel
Con rods: Billet steel
Pistons: Billet aluminium
Intake systems: Single plenum - carbon-fibre
Throttle systems: Electronic throttle control
Electronic control unit: McLaren Electronics - TAG-400I
Engine service life: 2500-2850 miles
Gear shift: Steering wheel mounted paddle shift
Im a huge F1 fan (McLaren) but I think this one has it beat in looks.
02-14-20 01:46 PM - Post#2786515
And the Alpha Dog - F1 ride
Attachment: EQwnvmZWsAQoINs.jpg (71.27 KB) 0 View(s)
pauldian
pauldian
Loc: seligman,arizona
Reg: 05-14-09
02-14-20 07:14 PM - Post#2786537
Im a huge F1 fan (McLaren) but I think this one has it beat in looks. Same here !
Execution time: 0.139 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:10 AM
