Username Post: parts        (Topic#359795)
rod
Member #248 Senior Member
Loc: kingman,az
Reg: 04-29-00
02-13-20 07:55 AM - Post#2786411
9" Ford Nodular iron "N" case, bare, $200
5.67 Schiefer Pro-Gear R&P, with Lenco stem and 1350 companion flange $125
Richmond 5.67 R&P, $75
US Gear 6.20 R&P, $100
Chevy factory cast iron tach drive, single point, window cap dist. $150
Weber alum. dual point dist, $10
Mallory YL 1 pair[2 total], points & condenser, $25
Mallory YC 2 pair [4 total],2 condensers & 1 rotor $50
SBC Chevy 168 tooth flywheel, brand new, 30 lb.,SFI legal, Long/B&B patterns. $175. will split ride
McLeod 10 1/2" B&B PP with hi=speed TO bearing,SFI legal, fresh $150
RAM 10 1/2" 6 puck metallic disc, 1 1/8"x10 $90
all 4 above parts, $350. will split ride
if you dont like the price, call with a reasonable offer.
parts + ride, except as noted
Rod 928/565-3120 AZ [MST] 8AM-8PM
Execution time: 0.152 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:54 AM
