Username Post: 1959 Roman Red        (Topic#359784)
MoboMac
MoboMac
Reg: 08-22-11
02-11-20 09:34 PM - Post#2786343
Need to do some touch ups..
Looking for a current/modern paint code for my local supplier to mix for me.
Any input is appreciated..
formerly Cameo Coral.....now appearing as MoboMac
Franks 59....
http://www.youtube.com/watch?v=UokRArv4eSo
This car and vid is ART!
Turn it up & go full screen....
Lead sled 61
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
02-12-20 01:13 PM - Post#2786383
    In response to MoboMac
Doesn't your supplier have different manufacture books with the color samples you can take out in the sun so you can choose your color? The paint code will be with the sample you pick
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
MoboMac
MoboMac
Reg: 08-22-11
02-12-20 06:44 PM - Post#2786394
    In response to Lead sled
In a perfect world.....I'd just drive the car there.....and they would just scan a panel...and mix from that...BUT...said car...is a dead horse...in the back of my shop.....
That being said....I would take something there to scan....but need figure out something that is good enough to scan....and easy/small enough to remove and take there...
Franks 59....
59cheviac
Loc: the sunshine state
Reg: 10-31-03
02-13-20 02:30 AM - Post#2786404
I've used the wiper grille. Easy to get off and easy to carry. If they want something flatter, I have also used the small bracket that bolts to each fender and holds the forward bolt for the hood hinge. One advantage to this piece is it usually hasnt faded the way outside pieces sometimes have.
Edited by 59cheviac on 02-13-20 02:33 AM. Reason for edit: No reason given.
MoboMac
MoboMac
Reg: 08-22-11
02-13-20 04:38 AM - Post#2786406
    In response to 59cheviac
Good call.....I'll give that whirl....
Franks 59....
Techhead
Techhead
Loc: Etobicoke, Canada
Reg: 10-25-05
02-13-20 10:42 AM - Post#2786423
Here is a place that sells the paing by the quart.
https://www.dansclassic.com/product.cfm?p=24212&am...
58 Delray in disaray
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
02-19-20 09:49 AM - Post#2786851
Maybe use a valence section.
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
MoboMac
MoboMac
Reg: 08-22-11
02-20-20 10:19 AM - Post#2786929
    In response to wings59
That was my first thought......but original owner had already done some touch-ups there.....and color is off...
That's part of the reason...I need some correct paint..
Franks 59....
Execution time: 0.225 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:52 PM
