Username Post: Parking brake adjustment        (Topic#359783)
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-11-20 01:25 PM - Post#2786325
Does anyone know what the manual says about adjusting the parking brake? There doesn't appear to be any adjustment for the right side.
Jeff
02-11-20 06:13 PM - Post#2786336
    In response to bowtie44s
Are you talking about the cable itself or the internal adjustment if 4 wh disc?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-11-20 07:08 PM - Post#2786337
The cable. The equalizer will tighten the right side but I don't see a way to tighten the left side.
Jeff
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
02-12-20 02:52 PM - Post#2786389
Did you mix up your sides? First post stated adjustments to right side...2nd post stated adjustment for left side.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-12-20 08:10 PM - Post#2786397
    In response to scrambldcj8
Yeah, I said them backwards in my first post. The right side screws into the equalizer. You can adjust it. The left side hooks to the front cable that runs through the floor and to the pedal. I don't see an adjustment anywhere.
Jeff
scrambldcj8
scrambldcj8
Reg: 04-06-03
02-13-20 06:39 PM - Post#2786450
My 1994 SUV K Blazer has an adjuster under the drivers door, along outside frame rail, that can take up slack. Your Pickup?
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-14-20 07:34 AM - Post#2786478
Yeah mine is an 88 truck. There is no adjustment there on mine.
Jeff
Sabino
Reg: 07-16-05
02-15-20 07:54 AM - Post#2786570
I don’t know anything about your year but, in general - if the system is a cable from the parking brake pedal to one side and the other side is a clip over that cable to the other side then the single adjustment on that side tightens both as the clip can slide on the “main” cable. My 68 Camaro has this arrangement. Forgive me if you already know this and that’s not your problem here.
65 Belair 350
68 Camaro 327
93 Suburban 5.7L TBI
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-15-20 06:23 PM - Post#2786610
    In response to Sabino
I'm not sure I'm following you. The equalizer over the left cable and locks in place. It doesn't move. The right side threads into the equalizer and there is about 4 inches of adjustment there. I don't see how that will have any affect on the left side as it locks over the outer "sheath" and has nothing to do with the inner cable.
I'm sure you're right, I'm just not understanding it.
Jeff
scrambldcj8
scrambldcj8
Reg: 04-06-03
02-16-20 06:08 AM - Post#2786627
Does #9 adjust?
https://www.lmctruck.com/1988-98-chevy-gmc/bra kes/...
Sabino
Reg: 07-16-05
02-16-20 08:04 AM - Post#2786634
I didn’t describe it well. The cables from both parking brakes form a “loop” and “hook” over a bracket on the cable from the parking brake pedal. Because the “loop” going to rear parking brakes can slide on the bracket - adjusting on the bracket tightens both sides. Probably easiest to google 68 Camaro or nova parking brake and it’s obvious, better than my description
If your cable from either side connects to the cable from parking brake cable such that it is fixed - it’s not your case.
65 Belair 350
68 Camaro 327
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-16-20 09:16 AM - Post#2786646
It is just like the link that scramdldcj8 posted. I googled the 68 Camaro and I can understand how that works. This is a different setup.
#9 is the equalizer and it does adjust, but only where the right side screws in. The front of that equalizer clips over the left side cable and is locked in place. It doesn't move.
Jeff
Sabino
Reg: 07-16-05
02-16-20 12:10 PM - Post#2786664
Maybe one of the parking brake schematics in this link will give a clue? https://nemigaparts.com/cat_spares/epc/chevro let/5...
Seems if one side is adjustable, then only other possibility is the main cable is adjustable up by brake pedal? adjust left side with that and then other with the "adjuster"? no clue good luck!
65 Belair 350
68 Camaro 327
scrambldcj8
scrambldcj8
Reg: 04-06-03
02-16-20 04:06 PM - Post#2786680
I just had to go take a look at my '94 pedal arrangement....I don't see any adjustability at the pedal end....?
Edited by scrambldcj8 on 02-16-20 04:07 PM. Reason for edit: No reason given.
Sabino
Reg: 07-16-05
02-16-20 04:42 PM - Post#2786683
Now I’m curious. I have service manuals for a 93 and when I got home checked it out. Seems adjustment is done in rear brake on this year. Don’t know about earlier. I can’t attach photos of manual but if you PM me email I can email them.
65 Belair 350
68 Camaro 327
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-17-20 09:11 AM - Post#2786720
I was wondering what the manual said about it. It says you have to adjust it inside the drum?
PM sent
Jeff
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
02-17-20 04:02 PM - Post#2786753
I'll Chime in here...
If you have the equalizer bracket pictured, then there is only one screw to adjust. The way it all hooks together causes it to effectively adjust both sides.
That said, when only one side seems to adjust, you normally have a seized cable or parking brake arm inside the opposite drum. I suspect this is your actual issue here.
Attachment: 6021121-007__ra_p.jpg (24.07 KB) 6 View(s)
-91 Sierra C2500, now K2500
-81 Chev K20
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-17-20 08:02 PM - Post#2786771
    In response to stumppuller
I have the equalizer like pictured. My cables aren't seized. They are all brand new. Sabino sent me pictures from the service manual. It looks like you adjust the left side inside the drum.
Jeff
stumppuller
stumppuller
Loc: Canada
Reg: 11-01-04
02-18-20 11:08 AM - Post#2786797
Never encountered that before.
If you can, post some pictures of the setup. I'm curious to see what it looks like.
-81 Chev K20
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-18-20 06:44 PM - Post#2786819
It is exactly like the LMC Truck link Scrambldcj8 posted on 2-16-20. If you look there is no adjustment for the left side.
Sabino sent me pictures of the service manual showing adjusting the left side inside the drum where the cable hooks up. I just put on new shoes and hardware kit and don't remember seeing an adjustment there, but my truck doesn't have the original rear end.
Jeff
scrambldcj8
scrambldcj8
Reg: 04-06-03
10-02-20 12:40 PM - Post#2804671
Curious as to what you came up with? If nothing, could you use a cable clamp on the cable that you can't seem to adjust? Kind of hack I guess but if you could use a cable clamp to take up some slack it just may work. HECorp (Hack Engineering Corp) >>> LOL
Execution time: 0.095 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:16 AM
