Username Post: Gas tank        (Topic#359780)
probelair
Gold Supporting Member
probelair
Reg: 11-01-19
02-11-20 11:44 AM - Post#2786315
Going to be dropping the gas tank on the 61 impala Bubble Top.
First how do we know know the size.
And how do i really determine if it should be replaced.
Dont like doing things twice.
probelair
probelair
Reg: 11-01-19
02-11-20 11:51 AM - Post#2786316
    In response to probelair
If i was to replace the tank and sending unit and straps has anyone bought there parts from Summit racing.
Reason being i have a 20 percent off till the 23rd and that would nice.
If not send me to what is correct or better.
Thanks as always.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-11-20 12:21 PM - Post#2786318
The Spectra gm31 is a direct replacement (put one on my '63). Skip the stainless. Sold directly, and thru vendors (such as Summit). The tank is 20 gal.
My opinion? For the approx $200, just change it. Eliminate any risks of contamination from accumulated 'gunk'. Change all tank internals while at it.
Useful data here:
https://www.gmheritagecenter.com/docs/gm-heritage-...
Pete
Edited by japete92 on 02-11-20 12:22 PM. Reason for edit: No reason given.
probelair
probelair
Reg: 11-01-19
02-11-20 01:07 PM - Post#2786321
    In response to japete92
That's the answer I was hoping for.
Thanks very much
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-11-20 02:46 PM - Post#2786330
Use and buy only the Spectra gas tank, its zinc plated like the originals. Other cheap tanks are painted tanks (junk).
My Spectra tank in my 62 is 15 years old and it looks as good as it did when it was new.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
Original58
Original58
Loc: Manitoba, Canada
Reg: 10-30-13
02-11-20 08:08 PM - Post#2786342
    In response to pvs409
Go for the Spectra. It is a high quality piece. Spectra seems to strive to provide a quality product that is North America made.
The tank and sending unit for my 58 matched identical.
Jeff
1958 Biscayne 283 Turbo-Glide 31,000 mi (now 35,000 and counting) driven daily
1966 Mustang Inline 6- C4 57,000 mi and growing daily
1929 Graham - Paige 612- the eternal headache that I will never sell
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
02-12-20 11:21 AM - Post#2786376
    In response to Original58
Buy the made in Canada Spectra tank. Rockauto shows which is which.
Member #2194
Edited by DonSSDD on 02-12-20 11:21 AM. Reason for edit: No reason given.
dmart90
Reg: 01-26-20
02-16-20 08:31 AM - Post#2786640
On my '61, it looks like I have a leak at the gauge unit on the fuel tank when it's full. Now that the fuel level has dropped a little, the leak is gone. Do I need to drop the tank to replace the gasket or can this be done with the tank in place?
junky
Loc: Northeast CT
Reg: 06-27-10
02-16-20 08:34 AM - Post#2786641
    In response to dmart90
On some cars, GM had a punched out hole in the trunk that has a cover glued down over it, for accessing the fuel tank sender. Look in the floor of your car to see if it has this cover. If not, you have to drop the tank to repair it. Also, you are assuming that it is the sending unit, however, I have seen tanks rust out on the top from mud being thrown up there, and staying wet. Also check for that possibility.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-16-20 10:44 AM - Post#2786655
    In response to junky
There is no access panel to the tank unit. You must drop the tank to replace the seal or the sending unit. The sending unit must be removed either way as the seal goes over the sending unit and then put in the tank. This will also give you the oportunity to look at the top of the tank for rust and be sure the tank doesn't need replacing.
If the sending unit is working fine then you can get away with just the seal, but be aware the unit maybe rusted enough not to get a good ground when replacing. I would recomend you replace the sending unit and filter and gasket.
Make sure you either drain the tank down or run it low on fuel, it will make you life much easier when removing.
Edited by turbo38s10 on 02-16-20 10:46 AM. Reason for edit: No reason given.
Execution time: 0.146 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:08 PM
