01burban
Reg: 06-11-19
02-09-20 01:49 PM - Post#2786192
I have a 2001 suburban that I used as a parts truck for an ls swap and drove it home and abs worked great. My daily driver is the same truck a 2001 suburban and my module was bad so I swapped it in knowing it worked perfectly fine and now the abs pump won’t turn off and is throwing the c0267 code. Could the module have gone bad sitting for a month with no power to it? I don’t understand how it worked great in the donor truck but now it’s faulty. Thanks in advance
02-10-20 01:50 PM - Post#2786243
In response to 01burban
That code is for an open in the ABS motor circuit. Check the fuse.
'08 GMC Acadia 3.6L SLE
2plus2
Loc: Mission,BC
Reg: 02-03-05
02-10-20 02:19 PM - Post#2786245
The continuous running is a common issue but is a c0265 code
The transistors that turn the motor on and off go bad
You cab get the board repaired pretty cheap
69 Canadian Pontiac 2+2 Convertible
Factory L48 350 Chev,TH350,PW,PT
99 Silverado RCLB 4.8 NV4500 14BSF 4.10's locker 6" Procomp 35'S
07 Town Car Loaded,Tinted,Getting Bagged |
Edited by 2plus2 on 02-10-20 02:26 PM. Reason for edit: No reason given.
2plus2
Loc: Mission,BC
Reg: 02-03-05
02-10-20 02:23 PM - Post#2786246
In response to 2plus2
https://circuitboardmedic s.com/silverado-kelsey-ha...
http://siaelec.com/product/chevrolet-sil verado-abs...
