Username Post: Help! Thermostat Housing Mounting Stud loose.        (Topic#359761)
ampico-kid
Reg: 07-12-17
02-09-20 11:39 AM - Post#2786180
My '63 Impala SS w/327 had a small coolant leak by the thermostat housing. It was the housing itself which was all pitted and potholed where the hose attached. I bought a NOS and prepped it to replace the original. When I went to install the new one I found that one of the two mounting studs wouldn't tighten. I removed the housing and the stud easily loosened and came up out of the threaded hole in the manifold. I removed the good stud to compare and found that the bad one was about 1/4" shorter than the good side. The stud had obviously been replaced at some point with a shorter version. I checked the depth of the two holes and that was case. I'm assuming that about a 1/4" piece of the original bad stud is still in the hole.
The question is....what do I do now? I'd rather not have to pull the intake manifold. Could I retap to a slightly larger stud? Use some kind of a hardening epoxy to anchor the stud in the hole? Is there something that will harden enough to hold the stud in place? Or should I ?? Never had to deal with this kind of a situation before...any advice would be greatly appreciated. Thanks. Bob
Verne_Frantz
Member #574 "61-64 Subject Matter Expert"
Verne_Frantz
Loc: Hightstown,NJ USA
Reg: 08-22-00
02-09-20 12:33 PM - Post#2786185
    In response to ampico-kid
Buy a Helicoil kit for a 3/8-16 thread and follow the instructions. The housing should be held down by bolts, not studs and nuts.
Verne
ampico-kid
Reg: 07-12-17
02-09-20 01:27 PM - Post#2786189
    In response to Verne_Frantz
Verne
Thanks Verne....it pays to ask questions in the right place. I had no idea such a thing as the Helicoil even existed. You learn something new every day. Thanks again. Bob
ampico-kid
Reg: 07-12-17
02-09-20 02:23 PM - Post#2786195
Verne
The bolts should be 3/8-16 thread. I assume they would each have a lock washer. What length are the bolts? Thanks again. Bob
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
02-09-20 06:18 PM - Post#2786206
No lock washers. I believe the bolts are about 1-1/2", but I'd have to wait until tomorrow to measure one.
Verne
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
02-10-20 05:28 AM - Post#2786219
I’d buy helicoil brand as well, some of the off brand ones are not as strong.
Member #2194
ampico-kid
Reg: 07-12-17
02-10-20 08:59 AM - Post#2786230
    In response to DonSSDD
OK..thanks for the heads up. I'll make sure it's a Helicoil brand.
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
02-10-20 09:04 AM - Post#2786232
I checked an original bolt and they are 1", not 1-1/2". Standard hex head. Originals have various head markings but "UR" is very common.
Verne
Just to be perfectly clear in case you're not used to normal bolt measurements, the length is the length of the threads, not the overall length. In the case of a bolt with a shoulder, it's measured from under the head to the end.
Edited by Verne_Frantz on 02-10-20 09:08 AM. Reason for edit: No reason given.
turbo38s10
turbo38s10
Loc: Agawam,MA
Reg: 09-17-09
02-10-20 10:11 AM - Post#2786234
Here is a good video on inserts. A little long but interesting. Seems Bigserts win out.
https://www.threadkits.com/big-sert/
https://www.youtube.com/watch?v=LpDduCVUy6w
Edited by turbo38s10 on 02-10-20 10:15 AM. Reason for edit: No reason given.
ampico-kid
Reg: 07-12-17
02-10-20 02:46 PM - Post#2786250
Verne
Thanks Verne....I understand. The only complication is that one of the holes was pretty badly mangled. Looks like someone may have tried to dig out the old bolt that was in there and replace it with the stud. One of the holes drilled out and threaded great. The other mangled one...not so sure. I've put some locktite on the threads before screwing the Helicoil sleeve into it. It seemed to screw in alright. I'm going to give it some time to cure before trying to tighten up the bolts. I may give it a shot tomorrow. I'll let you know how I make out. Thanks for all of your help. Bob
ampico-kid
Reg: 07-12-17
02-10-20 02:47 PM - Post#2786251
    In response to turbo38s10
Thanks...already checked out some YouTube videos. Very informative.....
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
02-10-20 07:32 PM - Post#2786273
I hope it works out for you. Those bolts don't have to be very tight as long as you have some good gasket sealer on both sides of the gasket (NOT RTV).
If you can torque the one to 15 ft lbs, it should be fine.
Verne
ampico-kid
Reg: 07-12-17
02-11-20 07:03 AM - Post#2786292
What's the finish on the bolts? Engine orange or natural?
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
02-11-20 08:23 AM - Post#2786298
Originally they would have had a dull zinc finish.
Verne
ampico-kid
Reg: 07-12-17
02-12-20 12:58 PM - Post#2786382
I wanted to clue you all in to the final outcome. I used the Helicoil insert to repair the damaged/rusted threads on my thermostat housing. I was very concerned because one of the holes was badly mangled and the drill seemed like it was all over the place. The Helicoil went in easy enough, and possibly a little too easy I thought, so I covered it with gel type locktite, inserted it, and let it cure for a few days. I reassembled it today and torqued it to about 15 ft.lbs. and all is well. I ran the engine up to operating temperature and no leaks, no surprises, so apparently all is well. Thanks Verne for the helpful tips and advice. It's much appreciated. Bob
Verne_Frantz
Verne_Frantz
Reg: 08-22-00
02-12-20 02:25 PM - Post#2786387
Glad to hear it worked out!
Verne
junky
Loc: Northeast CT
Reg: 06-27-10
02-12-20 08:12 PM - Post#2786398
Keep an eye on it when the engine gets hot, because Locktite is released with heat, depending on which one you used. They make a Locktite that is specifically for loose threads.
ampico-kid
Reg: 07-12-17
02-13-20 08:53 AM - Post#2786419
    In response to junky
The formula I used indicates that it has a temperature resistance range of -65F to +300F. I hope my intake manifold/thermostat housing never sees 300 degrees F. Thanks for the heads up though, I'll keep an eye on it.
Execution time: 0.197 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:07 AM
