Username Post: Ticking 6.0        (Topic#359755)
02-09-20 09:44 AM - Post#2786163
A friend brought me an '04 Denali 6.0 with 233k miles. The right side has a ticking noise. I assume it's a rocker arm. Worse case, a bad lifter. No engine codes are present. Are these motors known to get loose rocker arms? Is zero lash the setting? After it warms up, the noise practically goes away. However, a faint tick can be heard.
02-14-20 07:46 PM - Post#2786534
It is probably a lifter. The later models with cylinder deactivation had lifter problems.
1957 Cameo Carrier
02-17-20 02:40 PM - Post#2786736
    In response to wagonman100
Would this 6.0 have deactivation? Too early is it not?
jktucker92
jktucker92
Loc: West Richland, WA
Reg: 02-05-17
02-17-20 03:08 PM - Post#2786739
Yes, the Active Fuel Management wasn't available in the 6.0L until 2007. It was available in some GMC and trailblazer 5.3L in 2005.
As for your ticking noise, it could be a lifter. I had a '03 5.3L that developed a ticking noise at 175,000 and it was a lifter. What I discovered is that some of the lifter holders in '03 and '04 warped over time, and the lifter was being held in at a slight angle, which caused the lifter to rub the cam and damage the cam. I caught it pretty early, and just replaced the lifter and had the cam reground. I also replaced all the lifter holders to ensure it wouldn't happen again. It ran great for another 25,000 miles and then I sold it. In order to confirm that, if you can isolate which lifter you think is causing the problem, you can remove a rocker and see if the noise goes away. If it does, you know what the problem is. Unfortunately, you have to remove the head in order to remove a lifter. It is possible to remove a cam without removing the head, but I've never tried it.
The other possibility is piston slap. These engines are notorious for piston slap, which I'm told is harmless, but even my '02 Tahoe had a distinct ticking noise when cold when it was new.
02-20-20 06:30 AM - Post#2786913
    In response to jktucker92
Where's the ticking lifter noise heard? Deep inside the block? Or up high on the valve cover. From hearing the engine run, I think it's the #2 or #4 area making the tick. I'll have to use my mechanic stethoscope to get a better idea. Yup, removing the head is no joke to fix a lifter.
jktucker92
jktucker92
Reg: 02-05-17
02-20-20 12:15 PM - Post#2786935
As I recall, the ticking lifter I heard sounds like it's coming from the top of the engine, but not the valve cover area. If the cam is badly worn, you'll hear a ticking noise from the valve cover area because a small gap has developed between the pushrod and the rocker arm. In my case, there was just a scar on the cam and a matching one on the lifter. Below is a link to a Youtube video with damage to a lifter that's a little more severe than mine was.
https://www.youtube.com/watch?v=g8rQdqR00es
64ss409
Reg: 12-04-02
02-21-20 06:43 PM - Post#2787022
I have had ticks that I thought were valve train, but turned out to be a cracked exhaust manifold. Yours may not be, but I thought I would mention it.
Ron
02-24-20 05:42 AM - Post#2787179
    In response to 64ss409
Wow! I'll use a mirror and check the exhaust manifolds underside. I've an I5 with a cracked manifold. I should say, it's a single consistent tick.
Edited by gchemist on 02-24-20 05:42 AM. Reason for edit: No reason given.
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
02-24-20 06:34 AM - Post#2787182
Remember, these trucks are prone to breaking the forward and aft most manifold bolts. Dorman sells a "fix" for this that actually works pretty well.
When my 06 broke the bolts, I bought a set of aftermarket header gaskets made of soft copper. I changed out all the bolts with stainless, and never had another issue...
Execution time: 0.119 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:56 AM
