Username Post: Engine Re builder In Houston, Tx Area        (Topic#359739)
nomadmangizmo
nomadmangizmo
Loc: Houston,Texas
Reg: 09-16-04
02-07-20 05:08 PM - Post#2786084
Howdy ! As most of you guys know Hurricane Harvey came to the Gulf Coast and unfortunately put our house and 56 Nomad 3 feet under water.
My son and I have been slowly pulling the car apart (again) and getting it cleaned up etc. That being said, we had installed a 350 GM crate that was suppose to be about 260 hp.GM Engine#10066036 / 4 Bolt. While we have it out of the car, we figured it is time to finally help it get closer to or a tad better that 400 HP as I'm thinking that might be the best this block can handle.
We have completely disassembled the engine down to the bare block and upon a close eyeball inspection, it appears the block is in great shape. The engine had less than 10 k miles when it went under water. I drained the Harvey water, flushed the engine and filled it with fresh oil so no Rust is on the cylinder walls etc.
We are looking for a good engine builder in the Houston area for ideas and the skills to get us there. Just an FYI. it had a Turbo 350 trans, but I'm going with a 700 R4 after the engine work is done.
Thanks in advance for any reply
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
02-07-20 06:43 PM - Post#2786089
    In response to nomadmangizmo
Houston engine and balance on shaver in Pasadena,
There is another shop that does machining by hobby airport it is called USA racing engines.
heads reworked at USA, no issues
All I know
VC56S 2 door Sedan, 39 Years
nomadmangizmo
nomadmangizmo
Loc: Houston,Texas
Reg: 09-16-04
02-07-20 08:55 PM - Post#2786100
    In response to Bad56Sedan
Thanks......that is the second good report I've received from Houston Engine and Balancing.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
02-08-20 07:05 PM - Post#2786139
Seems both shops have been around a long time,
I can say Houston Engine and Balance has been at the same location for at least 40 years.
I' m sure USA has been around about the same amount of time just with a few different names.
I would recommend either shop, but then I have no idea where else to go.
Other smaller shops sub work out to both shops.
Houston Engine did a 327 for me a while back, no issues,
And as I previously posted USA did a set of heads for me, no issues.
nomadmangizmo
nomadmangizmo
Loc: Houston,Texas
Reg: 09-16-04
02-09-20 03:39 PM - Post#2786198
Bad56Sedan
I was talking to another buddy and he mentioned both shops and that they both had good reputations. I'm going to head over there way Tuesday and have a visit with them.
Thanks again !!
Russell
Execution time: 0.158 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:14 PM
