Dean50
"18th Year" Gold Supporting Member
Loc: Detroit area
Reg: 01-02-07
02-03-20 03:58 PM - Post#2785810
Added a stronger Edelbrock cam and a different bellhousing with an engine adapter we made. Painted the engine compartment while the engine was out and made new fuel lines. Powder coated intake and valve covers and ceramic coated the headers. New air filters, new distributor and MSD ignition. Hopefully have it running this week.
Dean50
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
02-03-20 04:44 PM - Post#2785815
In response to Dean50
Looking very good!
hpva
Loc: Kinderhook NY
Reg: 03-31-13
02-03-20 04:55 PM - Post#2785819
That looks great, good job.
dsacton
Loc: Boulder, CO
Reg: 11-01-11
02-03-20 05:17 PM - Post#2785822
Nice! Sure wish I could be there when you fire it up.
Dean50
Loc: Detroit area
Reg: 01-02-07
02-03-20 05:56 PM - Post#2785824
In response to dsacton
Oh yeah! Thanks, guys.
I'm hoping this cam will wake up the fuelie heads and those four outside barrels a bit more!
Dean50
2D51STYDLX
Loc: So. Prairie Washington
Reg: 03-03-11
02-03-20 06:47 PM - Post#2785828
Purdy
Roger
1951 2 door Deluxe Bone stock, well not quite, bucket seats.
Broken hearts and dirty windows
Make life difficult to see
Thats why last night and this morning
Always look the same to me
John Prine
"19th Year" Silver Supporting Member
02-04-20 09:24 AM - Post#2785859
In response to 2D51STYDLX
Nice job on the fuel lines.
1953 210 Convertible, 261 with dual Carter YF 966S carbs, P.S., Remote Bendix P.B. Booster.
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-04-20 10:28 AM - Post#2785869
Nice that you kept it period Chrevrolet...looks like something GM might have put together; like something that engineering and design depts. may have collaberated on.
1951 Fleetline Preservation
'51 Fleetline DeLuxe, POWERglide 2-DR (Fathom Green)
'53 6500 Dump Bed (Faded Red)
'50 Styleline DeLuxe 4-DR (Mist Green) |
Dean50
Loc: Detroit area
Reg: 01-02-07
02-04-20 03:40 PM - Post#2785896
In response to RAM_51
Thanks to all for the compliments. My son Aaron did the build on this.
Dean50
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
02-04-20 06:10 PM - Post#2785909
Are you still running the enclosed drive line, just curious if the extra power is going to shove that original 3speed over the edge
Bill Wilson 50 styleline deluxe 2 door sold,- 51 styleline Deluxe 2 door ,'56 235 with dual carter webers on an Offenhauser intake, Fenton headers, 56 chevy rear end and 700R4 transmission. |
Dean50
Loc: Detroit area
Reg: 01-02-07
02-04-20 07:52 PM - Post#2785915
In response to one4dad
Yes, still torque tube and three on the tree with a PG 3.55 rear. I power it on gradually except when the tri-power kicks in and that's when it's already cruising. No burnouts here!
Dean50
one4dad
Loc: Baton Rouge La
Reg: 01-17-10
02-04-20 08:31 PM - Post#2785919
Dean50
Loc: Detroit area
Reg: 01-02-07
02-16-20 08:54 AM - Post#2786633
Got 'er done. Drove back to my place the other day. Added an MSD ignition box under the battery tray and MSD coil. Couple of small details to do but it drove nice on a cold day.
Dean50
Jeff1951
Loc: Bloomfield Township, MI
Reg: 11-12-18
02-16-20 10:44 AM - Post#2786648
Dean,
Looks great! Well done. I'm looking forward to seeing it this when the weather here in Detroit breaks.
Jeff
tommy49
Reg: 09-28-12
02-16-20 11:48 AM - Post#2786656
Outstanding job, Dean!
Dean50
Loc: Detroit area
Reg: 01-02-07
02-16-20 03:30 PM - Post#2786673
In response to tommy49
Thanks, Jeff and Tommy. Credit goes to my son Aaron. I'm happy with the way it turned out.
Dean50
50hotrod
Reg: 07-25-11
02-17-20 11:36 AM - Post#2786726
Looks great. I really like the black.
You said you are running an MSD ignition.Is it the 6AL? If it is, I might be wrong, and the picture might not be showing the correct size, but the plug wires look small for that system. Also the coil wire looks stretched.
I had the coil mounted similar to yours and the wire came out part way because of engine movement. She still ran but was arcing and burnt the nose of the coil thru on one side. Only found it because I kept smelling something burnt under the hood. Cost me another MSD coil.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
Dean50
Loc: Detroit area
Reg: 01-02-07
02-17-20 03:29 PM - Post#2786740
In response to 50hotrod
Thanks 50hotrod. Yep, need a longer coil wire. It is a Model 6200 MSD box. I'll check about the plug wires. Thanks for the tip!
Dean50
GreatNorthWoods
Reg: 03-31-02
02-26-20 03:53 AM - Post#2787365
Love it!
Vern
1930 DeSoto CK Business Coupe- 350 Chevy Crate V8, 4-wheel disc brakes, TH400, S-10 Rear, Heidt's IFS, A/C |
Dean50
Loc: Detroit area
Reg: 01-02-07
02-26-20 04:40 AM - Post#2787366
Thanks, Vern!
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-21-20 09:16 AM - Post#2789126
The main purpose of pulling the engine in the first place was to swap bellhousings from the modified '63 Vette in the top photo to a '62-'64 Nova to get a more natural position of the clutch arm (to 5:00 from 3:00). Made an adapter plate to mate the stock 1950 3-speed using an extra borrowed trans. Bending, bracing and lengthening the offset arm was needed and now the clutch action is much smoother than before. The clutch link action is now parallel like the stock '50 rather than angled down.
Dean50
2D51STYDLX
Reg: 03-03-11
03-21-20 12:53 PM - Post#2789147
I got to ask what is the thigamajig between the coil and the rear carb ? I really like clean and simple, you guys nailed it !!!
Roger
John Prine
Dean50
Loc: Detroit area
Reg: 01-02-07
03-21-20 02:38 PM - Post#2789156
Thanks Roger.
It's a Moon air breather, attached to the valve cover.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
03-27-20 03:46 PM - Post#2789578
Here's a short video of the Chevy idling with the new cam. It actually sounds better in person.
https://youtu.be/v_zVYwUs7xA
Dean50
Member #189 Moderator and "22nd Year" Platinum Supporting Member
03-27-20 10:02 PM - Post#2789599
Sounds good.
29-41, 42-48, 49-54 Moderator
2019 Ford Ranger Lariat Super Crewcab |
