Username Post: Serpentine belt        (Topic#359694)
FINIS-55
FINIS-55
Reg: 03-01-13
02-03-20 08:30 AM - Post#2785781
Anyone running a serpentine belt set-up on a 55 Chevy with a small block? What motor mounts do you have, front or side? What water pump, long or short? Wondering about fit and clearance issues with frame.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
02-03-20 08:51 AM - Post#2785783
    In response to FINIS-55
I have a '57 SBC running an Alan Grove Components serpentine belt system. As far as I know all serpentine systems use a long water pump. I also have my radiator in the 6 cylinder position with two Spal fans on it. Works great even here in our Texas summers. I am using side motor mounts with a cross member for the rear mount. No issues with fit or clearance with the frame.
FINIS-55
FINIS-55
Reg: 03-01-13
02-03-20 02:03 PM - Post#2785805
    In response to 5Larry7
Hi Larry, thanks again.
asbicca
asbicca
Loc: Southern California
Reg: 07-18-03
02-04-20 09:12 PM - Post#2785922
[image][/image]
[image][/image]
Billet Specialties is the one I used and it is one of the narrowest ones available.
http://s2.photobucket.com/albums/y40/asbicca/55 %20...
Execution time: 0.14 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:50 PM
