Username Post: what can you add or point out on 1987-90 abs brakes        (Topic#359672)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-01-20 05:49 PM - Post#2785639
one thing I learned long ago... ask questions, you'll be amazed at what other people know that you might not know,
or remember.
Ive got a guy in my shop that has zero brake fluid pressure on the pass side front brake caliper feed line
there does not appear to be anything wrong with the master cylinder as the drivers side front brake works fine
and if I bleed the brake theres zero fluid pressure reaching the pass front brake, there appears to be no line damage so the brake
modulator valve,behind the divers seat looks to be defective? or some pressure sensor or perhaps a fuse is blown?
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
02-01-20 11:41 PM - Post#2785659
    In response to grumpyvette
YA READ THIS ON DC ? MIGHT HELP, IM ONLY GOOD ON AIR BRAKE ABS
https://www.digitalcorvettes.com/threads/calling-a...
PLUS
After doing some extensive research, the crew at Corvette Salvage has determined that the Brake Pressure Modulator Valve (ABS Pump) within 1986 to 1991 Corvette models is prone to failure. Many components within the pump tend to break down due to the corrosive nature of the hydraulic braking fluid which causes the pump to quit functioning properly.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-03-20 04:04 AM - Post#2785752
    In response to TAT_2
thank you
Execution time: 0.105 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:33 AM
