Username Post: sending unit filter        (Topic#359671)
995jim
995jim
Loc: Ohio
Reg: 12-17-06
02-01-20 06:34 PM - Post#2785638
Hi ,does anyone know what the micron count on the filter in the gas tank for a 65 impala would be?
thanks jim
65' Impala SS, 65' Belair, 89' Silverado Z71, 95' Silverado Z71, 12' Silverado, 15' Silverado LTZ, 16' Tahoe LTZ
"16th Year" Platinum Supporting Member & Senior Moderator
02-03-20 01:35 AM - Post#2785750
    In response to 995jim
Don't know Jim. Mine clogged up and I got a new "sock" from the dealer.
fsc66
Loc:
Reg: 05-05-12
02-03-20 07:19 AM - Post#2785765
    In response to 427SS65
Scroll down to fuel filter sock, looks like either 3/8 or 5/16.
https://www.oreillyauto.com/shop/b/fuel---emissio n...
Paul
65_Impala
Reg: 12-29-02
02-03-20 11:26 AM - Post#2785787
My guess would be fairly high, like 100 plus. What are you wanting this info for?
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
02-03-20 07:38 PM - Post#2785830
    In response to 65_Impala
I was gonna say see if a human hair passes through the mesh, but there's such a wide variety of thicknesses of hair like 20 to 180 microns so that doesn't help.
Anyway the sock is no substitute for a proper in- line fuel filter or the one at the inlet of a Rochester carb.
You can't put it over your nose to ward off Corona virus either
Ryan
Build date Dec. 21 '64 Oshawa
995jim
995jim
Loc: Ohio
Reg: 12-17-06
02-04-20 06:02 PM - Post#2785907
Im going to use an electric pump and recommended filter is 100 micron upstream. Currently I don't have a sock on the sender tube in the tank but thought I could mabe save some room by putting a new sock on the tube in the tank as Im pressed for room. Its going on a 65 wagon so the tank is in side rear quarter.
65_Impala
Reg: 12-29-02
02-05-20 11:00 AM - Post#2785949
I'm a rebel. I've been running an electric EFI pump for 10 years with no filter before it and no issues.
You'll be fine with a sock on the pickup. The factory in tank stuff only has a simple filter like that.
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
02-05-20 01:41 PM - Post#2785958
X2
Execution time: 0.157 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:24 AM
