Username Post: Will this damage an electric fuel pump?        (Topic#359662)
timh651
Reg: 11-20-19
02-01-20 10:23 AM - Post#2785599
I have a 2003 chevy s-10 with a 4cly motor. When I fill up my gas tank, I top it off completely into the neck. The last time I was getting gas, their was a guy at the gas station with a tow truck. He warned me to stop doing that. He said that when you continue to fill the tank past the point that the gas hose shuts off, the fuel pump will have trouble reading how much gas the tank has and can burn up the fuel pump. He said he's seen this happen a bunch of times. Can anyone else here tell me if this is true?
2plus2
Loc: Mission,BC
Reg: 02-03-05
02-01-20 01:51 PM - Post#2785613
    In response to timh651
He has no idea what he is talking about
Your gauge float will of maxed out inside the tank before the pump shuts off,so when you add that last bit of gas it doesn't read on the sender
69 Canadian Pontiac 2+2
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-02-20 05:56 AM - Post#2785669
Dont know about this damaging a fuel pump, but it will lead to an evaporative system failure and possibly splashed or spilled gasoline during the process. Lots of info out there, do a quick web search.
Edited by george88gta on 02-02-20 05:57 AM. Reason for edit: No reason given.
02-02-20 03:23 PM - Post#2785720
    In response to george88gta
Seconded
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
02-02-20 03:53 PM - Post#2785722
3RD IT.
THAY PUMP OUR GAS IN NJ,SO I USUALLY GET $20/25 WORTH FOR THAT REASON DEPENDING ON THE PRICE.SINCE THE GAS COOLS THE PUMP I NEVER LET IT GET BELOW 1/4 TANK.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
02-06-20 05:00 PM - Post#2786022
    In response to TAT_2
I do the same TAT. 1/4 tank is considered empty for me. And yes, you can damage the evap. system by overfilling but not the pump. I usually let the pump click off on it’s own and then add to the nearest dollar.
1957 Cameo Carrier
Don57
Don57
Loc: Illinois
Reg: 04-28-00
02-06-20 07:27 PM - Post#2786027
This is almost guaranteed. Keep doing it and you will eventually get a CEL. You'll be able to clear the code and it will keep coming back until you clear the line from the tank to the canister and you may have to replace that canister.
1957 3200 Stepside
03-07-20 10:34 AM - Post#2788128
    In response to wagonman100
i like to refill at 1/2 tank. another thing to remember is to tighten the cap only 2 clicks. tighter is not better it wears out the ratchet and you will have to buy a new cap.
Execution time: 0.138 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:17 AM
