Username Post: Carpet replacement...        (Topic#359615)
docjns1
Gold Supporting Member
docjns1
Loc: upstate NY
Reg: 11-12-19
01-27-20 05:22 PM - Post#2785303
Hi all, looking for your thoughts on what vendor/brand offers the best replacement carpets? I'm definitely going with molded but see a variety of prices, etc out there. From what I gather I'll be cutting holes for seat and console mounting ( & possibly gas pedal) and I'd like to have the best fit possible going in.
Thanks in advance for your input!
Steve
327 / 300 L74
M11 3 on the tree
12 bolt 3.31 open dif
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
01-27-20 06:32 PM - Post#2785311
    In response to docjns1
I bought Trim Parts carpet, but their carpet division has since been swallowed up by ACC.
Don't cut for the gas pedal, you only need 2 holes for the ball studs the pedal pushes onto.
I used chalk to mark where they could be felt under the carpet along with the seat studs and pushed through the marks with an awl.
A pointy soldering iron seals and enlarges the awl holes when poked through from the back of the carpet.
I made a cardboard template for how to cut around the shifter area and then chalk outlined it on the carpet.
Do you have the factory sound deadener in place?
If not, you need some aftermarket version about 1/4" thick to make the carpet fit right.
I bought the Trim Parts underlay and it was just thin torch on roofing material which was less than ideal.
Here's a good article with some carpet pics and installation tips if you scroll down to near the bottom of the thread.
http://z28camaro.com/our-cars-1965-impala- ss/
Don't buy 4 speed carpet for a 65-67 because the tunnel hump is low profile compared to 68/69, and since all carpets kits are made for 65-70, they're made to fit the later cars and look balloned out on the early cars.
Ryan
Build date Dec. 21 '64 Oshawa
rick1965
Loc: joliet ill
Reg: 12-07-16
01-28-20 07:01 AM - Post#2785336
i see your in upstate ny , so gonna offer a tip ive learned after a good many carpet installs, hard as it may be to wait to install new parts , a nice real warm sunny day does wonders for a molded carpet job. on the day you select to take it on , let it sit out unfolded in the direct sun for an hr or so and it will be much more workable to complete.you will get it right in under 5 cuss words guaranteed. cuz after they mold them , they roll em up and right into the box they go .
SSvert396
SSvert396
Loc: GA
Reg: 07-19-18
01-28-20 12:54 PM - Post#2785362
I put an ACC carpet in just last weekend. Pretty easy, install all your seatbelt and seat bolts/nuts, start in the center, once you get to a bolt or nut, put pressure on the top of them with a new razor blade and they pop right through. Only advice I got is ensure your footwell areas are pushed down well before you cut the edges off, I got close on one of mine (only about 1/2 inch under the sill plate.
Attachment: IMG_0577.JPG (830.21 KB) 8 View(s)
Attachment: IMG_0581.JPG (4.1 MB) 6 View(s)
Attachment: IMG_0587.JPG (3.17 MB) 9 View(s)
Joe
Restoration photo album below
https://www.tryimg.com/album/6DcY
1965 Impala 396 convertible
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
01-28-20 04:26 PM - Post#2785371
    In response to SSvert396
When you cut a carpet, do you have to seal the edge to prevent running?
1967 Grande Parisienne 4DR HT
My Flickr page
Oshawa65SS
Reg: 09-22-14
01-28-20 08:33 PM - Post#2785386
    In response to mjc1
No because of the plastic type backing of the carpet, and the edges are all covered except for under the dash where the cut is in parallel with the weave anyway.
The only sealing I did was with a soldering iron making the holes for the gas pedal ball studs, bucket seat studs, and seat belt holes.
Ryan
Bramlettjk
Bramlettjk
Loc: N. MISSISSIPPI
Reg: 12-19-08
01-30-20 06:29 AM - Post#2785447
Man, that is a pretty car. Thanks for sharing.
67 SS 396 CHEVELLE
65 SS 396 IMPALA
Life is easy, until you have four daughters.
docjns1
docjns1
Loc: upstate NY
Reg: 11-12-19
01-30-20 06:59 PM - Post#2785491
Thanks for all your input (easier to replay to all of you from here than individually)! For sure on the warm weather thing. Currently a replacement done very poorly by a previous owner....front half is crooked and wasn't cut for console mounts, hi-beam button, etc. No padding underneath as well. I'm looking at molded with jute backing and considering a heat/sound layer as well, probably the foil backed as they seem to be easily molded.
Steve
327 / 300 L74
M11 3 on the tree
Execution time: 0.174 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 AM
