Username Post: Valve spring bind        (Topic#359588)
sting199
Reg: 12-12-19
01-25-20 12:26 PM - Post#2785148
Firstly,,,got to say the help in this site has been super. THANKS EVERYONE!!!! Got a set of heads with upgraded springs (duel) and trying to figure max lift on the springs, to upgrade the cam (naturally). Got the coil bind about at .675, at room temp. Now, some Ebayers only leave .050 from max lift to coil bind. I am not keen on this, would like at least .100, and not sure how much more for heat expansion. What would be a safe max lift for these springs? Thanks!
01-25-20 01:55 PM - Post#2785150
    In response to sting199
.060 is the industry safe margin, also watch out for clearance from the top of the valve guide to the bottom of the retainer. Of course if you push it to valve float, that could cause problems.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-25-20 02:00 PM - Post#2785151
read the linked info, and sub links, for a great deal ,more related info
Edited by grumpyvette on 01-31-20 06:54 AM. Reason for edit: No reason given.
01-25-20 02:23 PM - Post#2785152
    In response to grumpyvette
Usual thorough stuff from the "Grump".
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
01-25-20 05:14 PM - Post#2785168
What is the shortest answer to this issue?
VC56S 2 door Sedan, 39 Years
Member #409
01-25-20 06:55 PM - Post#2785174
    In response to Bad56Sedan
Look at the charts/diagrams above.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-30-20 04:25 PM - Post#2785481
    In response to Rick_L
I guess I just don't see it.
My password at grumpy's sight don't work,
That's why I asked,
Member #409
01-30-20 06:08 PM - Post#2785492
You don't need grumpyvette's site. The diagrams are in the posts here.
01-30-20 06:33 PM - Post#2785494
What more do you need in addition to my or Grump's post?
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-30-20 07:44 PM - Post#2785498
Unfortunately, I don't see what you would need to do to solve the issue.
I see the diagrams but, I just don't see what you would do to gain clearance between the spring coils.
I guess I'm looking for something like,
" you cut the valve guides down"
"You cut the spring seats down"
That's all, just asking
Edited by Bad56Sedan on 01-30-20 07:50 PM. Reason for edit: No reason given.
01-31-20 06:42 AM - Post#2785515
Correct, given a certain valve spring that is what would be required to get the required clearances.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-31-20 06:50 AM - Post#2785516
both offset retainers and offset valve locks exist that will each allow .050 added height,or clearance, but be aware added space reduces the valve spring pressure , yes its very common for a cam with increased lift to require both the valve guide and spring seats to be machined and new valve seals and valve springs and retainers to be installed
Edited by grumpyvette on 01-31-20 07:16 AM. Reason for edit: No reason given.
65_Impala
Reg: 12-29-02
01-31-20 07:28 AM - Post#2785519
No-one has pointed out that keeping a valve spring out of coil bind isn't the only criteria that determines it's suitability with a certain cam. The seat and open pressures also have to be suitable for the cam.
Bad56Sedan - What you can do depends on what the issue is. You can cut the valve guides shorter if that's causing the issue. Sometimes, cut the seats and use different springs. Sometimes different retainers as Grumpy posted. It just depends.
http://www.engineprofessional.com/articles/EPQ215_...
Execution time: 0.212 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 PM
