Username Post: 63 Impala SS Horn        (Topic#359570)
ayelander
"2nd Year" Platinum Supporting Member
ayelander
Loc: Oak Island NC
Reg: 12-07-18
01-23-20 01:42 PM - Post#2784991
PO Put on a sports steering wheel but furnished the original steering wheel. I put the original back on and used the parts shown in the attached diagram. Can't get the horn to work (electrics are fine). Any hints on whats wrong?
Attachment: 20190820_160448_resized.jpg (811.32 KB) 5 View(s)
Ayelander - Oak Island NC
1963 Impala SS,500 HP,EFI 383 Stroker,Tremec 6 Speed Manual
1974 Corvette, 454 cu in, 4 Speed Manual
1951 Chevy 3100 Truck, 261 cu in, Dual 2-bbl Webers, Fenton Split Exhaust
2016 Chevy High Country, Diesel, Dually
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
01-23-20 01:49 PM - Post#2784992
    In response to ayelander
Parts 7 and 9 need to be correct for the wheel being used. You also need clean bare metal where the outer of part 6 contacts the wheel hub.
junky
Loc: Northeast CT
Reg: 06-27-10
01-23-20 02:25 PM - Post#2784995
Did the horn work when you received the car? If not, it might have a break in the circuit. The horn wire is black where it comes out from the bottom of the column, and it goes through the firewall to the horn relay. Make sure that the horn wire is plugged in where it exits the column. The horn works on a grounding system. Usually if the horn parts are installed incorrectly, the horn blows and no on knows what the did incorrectly. It is good that you have a clear diagram for the car.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-23-20 05:58 PM - Post#2785008
    In response to junky
Can you use a screw driver and make it work? take the wheel all back off and touch screw driver to steering column shaft to horn contact. If it works you have a part in backwards are in the wrong spot. If not it's a electrical problem some where in the wiring.
As stated it's a ground wire that when you ground it to the column.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
ayelander
ayelander
Loc: Oak Island NC
Reg: 12-07-18
01-23-20 07:43 PM - Post#2785021
    In response to Andy4639
The horn did work. Even when I replaced the original wheel it worked intermittently. Got the parts and the diagram from Ecklers and I assume they are right. Seems like something is missing' I will continue troubleshooting'
Edited by ayelander on 01-23-20 07:44 PM. Reason for edit: No reason given.
junky
Loc: Northeast CT
Reg: 06-27-10
01-23-20 07:46 PM - Post#2785023
turn over the large spring washer that has 3 holes in it. That is usually the culprit that goes in wrong. I believe that there is a good picture in the factory service manual.
ayelander
ayelander
Loc: Oak Island NC
Reg: 12-07-18
01-23-20 07:49 PM - Post#2785026
I will try it
doubleE
Loc: Eagan MN
Reg: 06-02-03
01-25-20 10:18 AM - Post#2785143
    In response to 55Brodie
This the problem I had when I restored and painted my stock 62' impala wheel. I had painted too much of the center hub so that part 6 when the horn ring is pressed - did not make a connection due to the paint. Had to sand the exes paint from the hub.
ayelander
ayelander
Loc: Oak Island NC
Reg: 12-07-18
01-26-20 06:22 AM - Post#2785193
    In response to doubleE
I will look at that.
Execution time: 0.197 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:35 PM
