Gold and Platinum Members will see no ads here.
Username Post: Searching the Forum        (Topic#359566)
Chevelle
ChevyTalk Community Manager
Chevelle
Loc: Dana Point, CA
Reg: 08-31-13
01-23-20 11:06 AM - Post#2784979
Quick Tip.
After selecting the search button, located across the button bar towards the top of each forum, select Advanced Search, you will be presented with the search window.
1. Select the forum you wish to search. If you are NOT a Supporting Member you will have to select "one" forum at a time. Supporting Members can search all at once. Why not join today?
2. Select the keywords you are searching for. If they are a phrase make sure you surround them in quotes " " ,and also select Boolean as the Mode. For single words (have to be more than 3 characters) you will need to select Normal not Boolean.
3.Select the date range you would like to look for.
NOTE: The database search results are limited to 500 results at a time.
Attachment: 2017-03-16_6-49-17.gif (33.16 KB) 73 View(s)
Chevelle
Community Manager
I'll be happy to help just ask.
Click here to become a Gold Supporting Member and we'll turn off the ads at the top!!!
Execution time: 0.273 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:10 PM
