Username Post: Synthetic to Dino Oil ?        (Topic#359562)
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
01-23-20 09:12 AM - Post#2784970
The car I recently bought has Synthetic Oil in it. I find the Dip Stick hard to read and was told Synthetic is like that, but not just that, I would rather just run 5W-30 Dino Oil (non-Synthetic) like I've been using all my life.
The Synthetic is also known to be thinner, as I am told, and I need to add more than what I believe I should be.
My question is, any problem switching over? I've heard some say yes, but mostly no.
Would like more opinions on it from you all here.
Member:
-National Impala Association
01-23-20 10:26 AM - Post#2784980
    In response to 62BillT
Some mis info here, it is not thinner, but does flow better in colder weather start ups, and no additional oil is required and you can switch back to Dino oil.
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
01-23-20 11:50 AM - Post#2784985
Thanks.
The "thinner" part is more of an assumption on my part as I've been told that high mileage engines should switch to "High Mileage Synthetic".
As you can tell the Synthetic business is all brand new to me. I just bought my first quart ever recently, only to add the same brand, weight and type to what is already in there.
Glad to see your green light on switching to Dino.
Member:
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-23-20 05:01 PM - Post#2785004
HIGH MILEAGE HAS A ADDITIVE TO SWELL SEALS IN BOTH SYN & DINO OIL.
High-mileage oils have ingredients to take care of older engines, like conditioners, seal swells, antioxidants, detergents and wear or friction additives. Typically they use a viscosity modifier that is durable and won't lose viscosity very easily. These oils need to stay thicker longer to protect engine parts.
THE WHEEL SEALS I USE IN WORK COMES WITH A GREASE TO SWELL THE RUBBER ON THE AXLE & IN THE HUB.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
junky
Loc: Northeast CT
Reg: 06-27-10
01-23-20 08:00 PM - Post#2785027
I would continue to use the synthetic oil, for its longevity (synthetics go longer between oil changes), and if you find reading the dipstick difficult, then lay it across a piece of paper like a McDonalds napkin, and you will see the oil mark. I run everything with Synthetic in the engines, except for my new engine in my '62, which is running break in oil for the first 1000 miles. Then it will also be switched over to synthetic oil...
Member #409
01-23-20 08:16 PM - Post#2785028
The 5W30 rating determines the "thickness" of the oil, it is the same whether it's dino or synthetic.
At one time synthetic oil was accused of causing leaks, maybe true then but not now. And certainly not on a late model engine because the gaskets and sealers will work with synthetic.
If you want to use dino oil because it's cheaper, the price has narrowed a bunch, and if you buy synthetic when it's on sale, it's the same or cheaper. Rarely do they put dino oil on sale any more.
Be open minded, synthetic is better stuff.
62BillT
62BillT
Loc: Moneta, VA
Reg: 09-24-01
01-24-20 03:01 PM - Post#2785093
    In response to Rick_L
Appreciate the additional replies.
Member:
65_Impala
Reg: 12-29-02
01-24-20 03:19 PM - Post#2785097
5W30 is 5W30 synthetic or not. Whoever is telling you that synthetic is thinner or needs more in the engine is wrong. You can use it just like conventional oil. The advantages are that it protects the engine better and can be run longer between changes.
If this car is driven a lot and needs multiple oil changes a year then I would stick with synthetic. You can extend the oil change interval and do fewer changes while protecting the engine better at the same time.
If this car is driven low miles every year and you do a yearly oil change no matter what the mileage is then conventional makes more sense.
Of course, if GM recommends synthetic in the engine then use synthetic.
TAT_2
TAT_2
Reg: 10-29-00
01-24-20 03:32 PM - Post#2785098
ILL ASK THE 64 $ ?
MOTOR INFO ?
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-24-20 05:12 PM - Post#2785100
    In response to TAT_2
IMHO...and I know next to nut'N...I do not like seal swellers, and if the inside of your motor is clean (from having a history of regular changes w/quality oil), then all that junk that is in high mileage oil, is just that, un-needed junk. I bet if you check your manual, it says don't use additives.
AND, man did I just throw out a discussion starter.
And, I'd run 10W-30 in dino oil (there is, or was, a thought out there that a wide spread between the cold weight (in this case, 10W) and the op-temp weight (in this case 30), is bad. Alls I know, is that I have several HIGH-MILEAGE motors that have used only 10-30 and it when a motor has over 250K on it, and still runs good.....
Synthetic is better, but in my dumb opinion, if a motor can last 250K and still run like a top, w/dino oil (w/5K changes), then that is all that you need.
65_Impala
Reg: 12-29-02
01-24-20 07:04 PM - Post#2785113
    In response to Stinky
That's an interesting "thought" on weight. Every oil is thicker when cold than when hot. It the idea was to have a smaller weight or viscosity change between hot and cold then you'd actually want an oil with a bigger spread between the numbers, not a smaller spread.
5W30 has a smaller cold vs hot viscosity (or weight) change than 10W30 does.
When cold, you want the oil closer to the hot viscosity so it easily flows so it gets to all the critical parts quicker which gives the advantage to 5W30 over 10W30. 0W30 would be even better for cold starts when the majority of engine damage occurs.
Overall, it makes no sense to run oil that is thicker when cold vs an oil that is thinner when cold. I don't think you will find very many sources that support a thicker oil as providing better cold start protection.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-25-20 08:25 AM - Post#2785135
I use 'dino' oil (10w40) in my '383' sbc and change it (and the filter) once a year (about 1500 miles). It may be my old eyes but it is hard for me to read the dip stick; the oil is always 'clean'. Junky's 'trick' helps me. I also only check it 'cold'. For my situation, it would not make any difference which type of oil I used.
Is synthetic 'thinner'? As previously stated, 10w40 is 10w40 regardless.
Going back in memory to days before multi-viscosity oils, one used 'lower' weight oil in the winter and 'higher' in the summer. Outside temperature when starting a cold engine dictated what weight to use.
My understanding (right or wrong) is that at a given outside temp (say 20 F) both 10w40 and 5w40 oil have equivalent flow characteristics when starting a cold engine. The 5w40 oil will retain adequate flow at lower temps than the 10w40. I would have to look up what the specific temp ranges each oil is recommended for; I'm too lazy.
Here's so info you may find helpful:
http://knowhow.napaonline.com/winter-oil-viscosity...
Because you asked for opinions, here are a couple of mine:
Old 'rules of thumb' are hard for me to break. I was taught not to change the type of oil an engine was 'used' to, w/o a very good reason. So I do not. Is synthetic 'better' than 'dino'? Likely so. Everything 'new' (about cars) has advantages over 'old' stuff. I'll keep doing things 'my way' because I like Frank Sinatra
Switch, or not. I don't think it's anything to be concerned about.
Oil 'additives' ? May be beneficial to keep an old engine running until scrapped, or rebuilt. They are superfluous on a good running engine, regardless of oil 'type'.
Pete
Edited by japete92 on 01-25-20 08:28 AM. Reason for edit: No reason given.
elcamino
elcamino
Reg: 03-30-00
01-26-20 06:32 AM - Post#2785195
    In response to japete92
I have used nothing but synthetic oil in all my vehicles since 1975. For many years people did nothing but bad mouth synthetic oil, yet today most new vehicles require it simply because mineral oil is becoming old technology, going the way of the bias ply tire.
A lot of old mechanics tales on synthetic oil and all are myth propagated by naysayers and technology haters.
What is synthetic motor oil? Synthetic lubricants are chemically engineered to form pure lubricants. They contain no contaminants or molecules that don’t serve a designed purpose. Their versatility and pure, uniform molecular structures impart properties that provide better friction-reduction, optimum fuel efficiency, maximum film strength and extreme-temperature performance conventional lubricants just can’t touch.
Conventional lubricants, on the other hand, are refined from crude oil. Contaminating elements such as sulfur, nitrogen, oxygen and metal components such as nickel or vanadium are inherent to crude oil and cannot be completely removed through the refining process. The oil refining process separates the various types of molecules in the oil by weight, leaving molecules similar in weight but dissimilar in structure, reducing performance.
Using aftermarket oil additives with synthetic motor oils is not only unnecessary, it could disrupt the oil formulation and reduce performance or worse, lead to engine damage.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
corvesy
corvesy
Reg: 08-07-08
01-26-20 07:06 AM - Post#2785197
    In response to elcamino
I have read that synthetic oil smokes less than petroleum based oil. A wife's tell or not?
01-26-20 09:13 AM - Post#2785207
    In response to corvesy
No factual truth here.
elcamino
elcamino
Reg: 03-30-00
01-27-20 08:58 AM - Post#2785280
If you are referring to 2-stroke oil (mixed with gas) than it can.
Not all synthetics are created equal, and it may be that not all synthetics are actually synthetic at all. Fully synthetic oil is a marketing term that in no way defines the quantity of synthetic content.
Reference
Lubes'N'Greases April & May 2019 columns by Thomas F. Glenn Petroleum Trends International & Petroleum Quality Institute of America; "How Do You Know Its Synthetic?".
elcamino
elcamino
Reg: 03-30-00
01-30-20 04:32 AM - Post#2785441
    In response to 65_Impala
value="transparent">
65_Impala
Reg: 12-29-02
01-30-20 07:04 AM - Post#2785452
Didn't hear him say anything about oil ratio???
Amsoil is the manufacturer those guys love to use though. The Saber oil is one of the oils they like mixing lean.
elcamino
elcamino
Reg: 03-30-00
02-07-20 08:45 AM - Post#2786055
They run Dominator Racing oil. Its tuned oil injection...premixing oil with gas is old technology rarely used today. The ratio they will never reveal so competitors don't gain an advantage.
The oil the race teams use it the very same oil you can buy, its not a special one-off oil just for a race team. Made in the USA in Superior, Wisconsin since 1972.
65_Impala
Reg: 12-29-02
02-07-20 11:33 AM - Post#2786067
I was referring to the guy I help with running Saber from the post that was deleted, not what the pro race team runs.
Anything Amsoil is a good oil.
Execution time: 0.16 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:12 PM
