Username Post: Big Block mounts        (Topic#359528)
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
01-20-20 07:10 AM - Post#2784714
So have decided to go Big Block in the new project.
Specifically a 454 we are going to look at tomorrow. Does anyone know what type and part number frame and motor mounts I will need to find?
As always, thanks for the help.
Steve65
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
brickwhite
brickwhite
Loc: Missouri
Reg: 09-05-19
01-20-20 08:32 AM - Post#2784720
    In response to steve65
What is currently in your Car. Alot of times you can you the towers that are there?
If not try these Towers.
https://www.summitracing.com/parts/gmk-4020-335694 ...
https://www.summitracing.com/parts/oer-3955184?rre ...
https://www.summitracing.com/parts/gmk-4020-335-67 ...
As for the actual Rubber engine mounts.
2 5/8" wide one
https://www.summitracing.com/parts/ani-2285
narrow
https://www.summitracing.com/parts/ani-2283/overvi ...
There are also poly ones.
https://www.summitracing.com/parts/ens-3-1117g/ove ...
These are the 327 mounts on my 66 impala.
Left (narrow)
Right (wide)
One tower is wider than the other.
So one will require a different rubber mounts.
One is 2 3/8" and the other is 2 5/8"
I have been told that the 454 will fit on the 327 mounts but I have not tried it yet. But will shortly when I swap the 327.
Ted
Edited by brickwhite on 01-20-20 08:34 AM. Reason for edit: No reason given.
steve65
steve65
Reg: 09-25-13
01-20-20 10:44 AM - Post#2784730
    In response to brickwhite
Thanks Ted,
No motor or tranny in it when I bought it last week, but cowl tag says it was a V8 car. I'm guessing 283/327.
Thanks for the info, I will look into your links.
Steve
Steve Duncan
66 Impala 2dr Coupe
work in progress
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
01-21-20 08:13 AM - Post#2784803
My 65 was originally a 327 car. When I swapped in a 454 the factory 327 towers had the correct dimensions.
I replaced the OEM rubber motor mounts with aftermarket poly mounts.
Johnny
1965 Impala SS
505/4-speed/3.90
mjc1
mjc1
Loc: Burlington Ontario Canada
Reg: 09-15-04
01-21-20 11:37 AM - Post#2784816
    In response to Johnny468
67 car for what it's worth.
327 to BBC on the original 327 towers no problem. Prothane mounts no issues.
1967 Grande Parisienne 4DR HT
My Flickr page
Execution time: 0.167 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:27 PM
