Username Post: Unbending door-panel stainless trim        (Topic#359525)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-19-20 07:24 PM - Post#2784694
Hi folks,
I just finished the door panels of my '54 and now am woking on the rear panels. (If it were a 4-door, they'd be the rear doors, but it's a 2-door, so I guess they are not actually door panels.)
One of the pieces is really bent (dumb move when I was a kid). I am going to straighten it. I was thinking of attaching wooden strips on each side of the bend, and then heating the "elbow" to be red hot and straighten it. Any thoughts on this? Or do you know a better way to unbend it?
Thanks for your help,
Attachment: IMG_5134.JPG (840.48 KB) 4 View(s)
Bent stainless door panel trim
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-19-20 07:40 PM - Post#2784696
    In response to dsacton
No heat take a small piece of hardwood or aluminum and form it do do half of the profile so you can move it from side to side. Do this from the back with the finish side on the plate.Lay it on a smooth plate a piece of steel or aluminum and with a small hammer you can tap on the the profile tool and bring it back out where it will look like new. I have done several pieces of stainless that way some bent over 90 degree's.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-19-20 07:54 PM - Post#2784698
    In response to cbmkr56
Are you saying that I should make a mold of sorts, and hammer it into the mold from the bottom? I'm a bit confused and would welcome any clarificaiton. Thanks
Scott Acton
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-20-20 12:47 PM - Post#2784738
I will take a picture of how to do it and post it.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-20-20 01:14 PM - Post#2784741
Hope this helps
Attachment: trim_1.jpg (24.41 KB) 54 View(s)
Attachment: trim2.jpg (2.76 MB) 16 View(s)
Attachment: trim3.jpg (2.51 MB) 7 View(s)
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
01-20-20 01:53 PM - Post#2784749
That's pretty cool.
Dean50
whiskey1954
whiskey1954
Loc: central north carolina
Reg: 12-07-08
01-20-20 01:58 PM - Post#2784751
Dsacton: Do not try to straighten it with one blow. You know the deal Love it, massage it, caress it. Like you do your "PETS"
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-20-20 04:07 PM - Post#2784763
    In response to Dean50
I do a lot of stainless repair on these cars, Windshield center trim from hoods blowing up and sun visor clamps. The front door trim that gets bent by the front fender when the strap breaks.
I have a few special made little tools from 6061 aluminum for certain pcs.
Yes take your time and let the metal help you put it back to where it was.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-20-20 05:37 PM - Post#2784771
OK, I see what you mean. You make a tool (wood or aluminum) to hammer from the back side, against a flat steel surface. But how do you make the initial corrective bend? Mine is bent about 30 degrees.
Thanks for the pictures!
Scott Acton
junky
Loc: Northeast CT
Reg: 06-27-10
01-24-20 07:01 AM - Post#2785055
Very slowly and carefully message it out a little at a time. Patience is the name of the game. If you don't feel comfortable doing it yourself, then send it to someone that does this for a living. It might be money well spent.
kool53
Loc: Mukwonago, WI
Reg: 06-18-04
01-24-20 05:49 PM - Post#2785101
    In response to junky
Not trying to hi-jack this, but does a shrinking disk have the same effect on stainless as it does on sheet metal? If I wanted to do a little shrinking on some trim, would that work?
eplantage
Loc: Southern MN
Reg: 03-15-04
01-27-20 08:32 AM - Post#2785277
    In response to kool53
I would say no. Polishing them would be a real pain after that. The pieces are not very wide, maybe 3/8". Patience is the key here.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-27-20 08:58 PM - Post#2785325
Finally got it finished; it is nearly perfect. I ended up building a small jig to keep the non-kinked portions of the strip flat while I worked the bend out. I used heat after all; I am not sure if that was necessary. But I am glad that it had a chance to anneal after bending it back.
I got some brass round stock and made a small chisel-like tool to work the wrinkles out against an aluminum plate the best I could. This seemed to be the perfect material to work the stainless, from the back side. 150 grit sand paper on the polished surface took out what was left. I worked my way up to 2000; I still need to use a buffing wheel.
Working out the dents created a bit of a bow; in hindsight, I wish I had stopped just short of completely unbending the piece, so it would be flat on the whole. But it will straighten itself when finally attached.
Thanks everyone for your help.
Scott Acton
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-27-20 10:18 PM - Post#2785327
Glad to here you got everything straightened out . I've had to go thru that bit of bodywork myself.Mine didn't come out "perfect", but all I had to work with, were hardwood dowels,hammers, picks and a whole lot of sanding,and hand polishing. Good enough for me
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Joe54
Loc: Alvarado Texas
Reg: 10-30-19
02-11-20 05:30 AM - Post#2786287
    In response to Lead sled
WOW!!!
Just watched your picture trail. From what I could tell you did an excellent job!!!
Execution time: 0.212 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:31 PM
