Username Post: Fog lamp moisture        (Topic#359491)
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
01-16-20 09:59 PM - Post#2784518
My 2015 Silverado fog lamp lenses are fogging up. Does anyone have a solution to the problem?
beagrizzly
beagrizzly
Loc: south texas
Reg: 08-04-12
01-21-20 08:10 AM - Post#2784801
    In response to dgstarr
It sounds like the seal under the bulb is bad. Either that, or the seal is broken on the assembly itself. If it is sealed, you will not get fogging at all.
Griff
1960 Biscayne (the 6T)
2005 Yukon XL
2007 GMC Sierra Classic 8.1
2009 Silverado
2011 Escalade ESV
dgstarr
dgstarr
Loc: Portland, OR
Reg: 04-16-13
01-21-20 05:02 PM - Post#2784834
    In response to beagrizzly
Thanks Griff for your response, I think it is the seal around the bulbs. I did not notice the moisture until I installed LED bulbs The bulb manufacturer says to try using a larger o ring on the bulb. I am going to try that along with using some high vacuum grease around the o ring.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
01-28-20 08:58 AM - Post#2785342
I just resealed a parking lamp by adding a seal I made from tool box drawer liner, to the existing seal.
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, Blazer rear axle, 4 wheel power disc brakes.
Execution time: 0.085 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:42 AM
