Username Post: 292 Mexican Block 6 cyl project        (Topic#359489)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-16-20 05:37 PM - Post#2784502
Purchased this with a car i bought Never started
THE Good Lots of new parts
14002009 L 20 8 Mexican Block over .060,New pistons 980P
New HO RV Camshaft 551M and Lifters and timing gear ( 12 bolt .com ),Crankshaft over .020 rods and mains ,New Clifford Valve cover and side covers, New HEI Dist New Oil Pump,New Offenhauser 4 bbl intake, New Cast iron Headers , 3895052 230 cyl head new valves and dual springs.
The bad Some idiot drilled a pin out of the rear of the crank thru the main cap into the thrust flange. Yes it can be fixed $200.00 line bore and $150 on thrust flange repair.
All the parts together i will not separate anything
I can send more pics if you PM me
$2000.00 Cash in hand when you pick it up.
Attachment: 292_block_1.jpg (128.8 KB) 5 View(s)
Attachment: 292_block_2.jpg (365.69 KB) 4 View(s)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-18-20 07:45 PM - Post#2784616
    In response to cbmkr56
Started the repair, too good to just get rid of.
Execution time: 0.209 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:36 AM
