Username Post: Not charging        (Topic#359485)
leknaw
Loc: SE USA
Reg: 01-02-15
01-16-20 01:26 PM - Post#2784487
I have a 1990 K1500, with a 98 Vortec, Edelbrock intake and carb. Also have a 1991 needles cluster. Had a short on the engine harness due to it making contact with hot exhaust manifold. Replaced the harness, replaced battery cables, replaced alternator, cleaned all contact surface for ground, still not charging. New battery was also added. Truck was charging just fine before replacing the harness. I have taking everything off and put it back on. Replaced the ECU, traced just about every wire I can think off. So I am begging for some assistance with this issue.I done research online and followed the different advice given and no luck
01-17-20 08:56 PM - Post#2784573
    In response to leknaw
voltage must be checked at the alt terminal post and at the battery post. not on anything else. repeat must be checked at the post. also, does the alt light stay on? are there fusable links?
leknaw
Loc: SE USA
Reg: 01-02-15
01-18-20 10:17 AM - Post#2784592
    In response to bobb
Thanks for the reply! Voltage at the terminal and alt the same, 11.6*. No lights inside. Checked bulbs, the were good replaced anyhow. Yes fusible links wires, which I have replaced already. Good continuity on them. Charged the battery again this morning and it showed 11.65 after one hour. Is only 3Months old at the most. Will replaced today and go from there! Once again, Thanks!
leknaw
Loc: SE USA
Reg: 01-02-15
01-18-20 10:29 AM - Post#2784594
Changed battery with a good known battery, 12.** volts, no change. Truly pizzle and frustrated.
Edited by leknaw on 01-18-20 07:43 PM. Reason for edit: No reason given.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-19-20 08:28 AM - Post#2784653
Quote,
“replaced alternator,” “was charging just fine before replacing” “Voltage at the terminal and alt the same, 11.6”
If you are only getting 11.6 volts at the alternator terminal you are probably only seeing what’s left in the battery. I would suspect the new alternator. Try another new one or your old one.
01-19-20 09:58 AM - Post#2784662
how many wires on your alt? get a schematic and start testing voltages
leknaw
Loc: SE USA
Reg: 01-02-15
01-20-20 04:43 AM - Post#2784704
    In response to YOUNG57
  • YOUNG57 Said:
Quote,
Thanks for replying! I have changed the alternator to the previous one and back, not luck!
leknaw
Loc: SE USA
Reg: 01-02-15
01-20-20 04:45 AM - Post#2784706
    In response to bobb
Two wires! I already follow the schematic! part by part individually. Checked the wires with the fusible links and they all test ok. Replaced the gauge cluster to ensure the problem came from there, nothing.
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
01-20-20 06:35 AM - Post#2784711
IDK....
is the alt energized, magnetic force production at back of alt? I am under the impression that an alt needs to be "excited" to begin producing current......I hate auto electrics...LOL
01-20-20 07:29 AM - Post#2784716
2? 3 is typical. 2 to battery. 1 to light in dash.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-20-20 08:17 AM - Post#2784718
You may try running a jumper from the BAT terminal on the back of the alternator to the #2 terminal of the two-wire plug on the side of the alternator to excite the alternator directly from battery voltage.
The #2 terminal tells the alternator how much voltage to produce by sensing voltage in the battery charging circuit from a common buss junction in the harness or the horn relay terminal. Installing a jumper just insures there is a direct connection from the charging circuit to the #2 terminal and not an open circuit or bad connection anywhere.
The #1 terminal applies alternator voltage to one side of the telltale light in the dash and the ignition switch applies battery voltage to the other side of the telltale light. If the two voltages are equal, or nearly so, the light does not burn. Engine not running or alternator not charging light burns. One-wire alternators do not use this circuit.
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
01-20-20 01:26 PM - Post#2784742
I'm just asking,
If you have the two smaller wires to the alt. only one should have voltage?
This is what "excites" the alt.
If this is correct, and I'm just asking,
Is it possible to disconnect the main wire on the back of the alt,
Start vehicle and check for 13.8 volts on the back of the alt?
Will this work?
It won't hurt to try.
Someone on CT has the wiring schematic for that truck.
Like the post above mine, geez I hate electrical issues!
VC56S 2 door Sedan, 39 Years
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-20-20 03:27 PM - Post#2784758
    In response to Bad56Sedan
There should be voltage on both the small wires of the two-wire plug, voltage on terminal #2 from the remote connection on the charging wire to the battery and voltage on terminal #1 back feeding from the telltale light in the dash (unless the bulb is blown or missing).
I don’t think it wise to energize or run the alternator with an open circuit to the battery (the wire removed from the BAT terminal). And it would not serve any purpose because if the alternator is charging that voltage can be measure at the BAT terminal with the charging wire connected.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-20-20 03:40 PM - Post#2784760
Yeah, just thinking it would prove if the alt was any good to start with,
Like OP said he has replaced some wiring
leknaw
Loc: SE USA
Reg: 01-02-15
01-21-20 05:51 AM - Post#2784794
    In response to bobb
Only two, always had the two! The red to the distribution block and the brown for the light!
leknaw
Loc: SE USA
Reg: 01-02-15
01-21-20 05:54 AM - Post#2784795
Very insightful, Will try this today!
leknaw
Loc: SE USA
Reg: 01-02-15
01-21-20 05:57 AM - Post#2784796
  • Bad56Sedan Said:
I'm just asking,
Will this work?
I have disconnect the one brown wire to the alternator and tested for voltage with zero volts. Will do the additional wire as mentioned by Young57 and see the results. Thanks!
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-21-20 01:10 PM - Post#2784823
1989 GM
Attachment: image.jpg (157.58 KB) 3 View(s)
Attachment: image.jpg (169.7 KB) 9 View(s)
Attachment: image.jpg (193.41 KB) 5 View(s)
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-21-20 01:13 PM - Post#2784824
Chart
Attachment: image.jpg (203.19 KB) 4 View(s)
leknaw
Loc: SE USA
Reg: 01-02-15
01-23-20 08:57 AM - Post#2784967
Awesome, Thanks Bad56Sedan!
leknaw
Loc: SE USA
Reg: 01-02-15
01-24-20 08:40 AM - Post#2785062
After a couple of weeks trying to figure out what is going with the truck, I think I came to a conclusion. Following the different diagrams presented here and searching the different years of the 88-98 trucks diagrams, I believe the culprit is the harness itself. 88-89 are the same, 90-93 are the same. 94 stands alone and I did no go further than that. The signal to the dash from the alternator on the brown wire, changes position on the firewall plug, so the circuit is not completed, therefore no charge or light on the instrument cluster. Working on piecing together a harness now and see if it works. If not to the junkyard tomorrow to pulled one from a 90-93 truck! Thanks to everyone that has contributed.
01-26-20 11:47 AM - Post#2785218
just switch the wire at the firewall connector. they can be unplugged from the connector individualy
leknaw
Loc: SE USA
Reg: 01-02-15
01-26-20 12:52 PM - Post#2785221
    In response to bobb
I went and replaced the harness altogether. Needed to insulated the spot closer to the manifold with anti-heat shrink anyhow. Got it started a while ago and it charges as it needs to. Thanks, everyone for all your help and assistance.
scrambldcj8
scrambldcj8
Reg: 04-06-03
01-27-20 09:09 AM - Post#2785281
Thanks for updating your post/findings!! It helps others in the future if/when they run across this in a search for help.
leknaw
Loc: SE USA
Reg: 01-02-15
01-27-20 01:09 PM - Post#2785291
    In response to scrambldcj8
Sure, No problem! When I can not figure out what is going on in my truck, this is where I searched the most information!
leknaw
Loc: SE USA
Reg: 01-02-15
02-05-20 04:31 AM - Post#2785927
So yesterday I went looking for a more complete, un-cut harness and found out a couple of things. I mentioned earlier on the differences and similarities of the harness throughout the years and here is something else. Even though the 88-89 are different than the later years, the harness cover/grommet on the passenger side firewall is the same, square with one screw. The 91-93 are the same as far as the diagram connections, but the above-mentioned cover on the 91-93 is rectangular with two screws. Just figure tis will come in handy!
Execution time: 0.181 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:38 PM
