Username Post: What oil to use        (Topic#359481)
mauryfrench
Gold Supporting Member
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
01-15-20 07:46 PM - Post#2784459
Me again. Last question tonight.
I had my oil change place do an engine flush and oil change since I just bought the 98, but plan to start changing my own oil again. With 205k miles, what is your favorite type oil? The Late Great Tom Brown from Parker Road Automotive had me using Castrol Conventional 20w50 in my last truck, that had well over 200k, with a quart of Lucasoil every second change.
I know some of you swear by the synthetics, but I haven't made the jump yet.
Thoughts?
Maury French
Wylie, TX
1998 Chevy ECLB 5.7 Vortec
thx1138v2
Reg: 05-01-14
01-16-20 04:14 AM - Post#2784465
    In response to mauryfrench
A friend explained synthetics to me this way: you have a room full of balls of all different sizes from ping pong to basket balls. That's non-synthetic oil. Synthetic oil is a room full of ping pong balls - all the same size.
If the truck has always run non-synthetic oil it is best to stick with it. Otherwise, you can get all kinds of leaks - gaskets, seals, etc. - where the basket balls used to seal those gaps you'll have ping pong balls going to that same location.
New car? Use synthetic.
That's my 2 cents worth.
Blueseasons
Reg: 10-13-11
01-17-20 02:17 PM - Post#2784553
    In response to thx1138v2
An engine flush? I always believed money was being flushed when they did those. But really, with that amount of miles. I dont think it matters. Just use the right viscosity and change it every 3k and use a good filter. I always use either Wix or AC Delco on my Chevy and Jeep. I started using Max Blend in the Chevy because it was affordable. I dont think my truck knows the difference between ping pong balls and soccer balls with a blend you get a little of both.
454cid
Loc: West Michigan
Reg: 02-18-12
01-17-20 03:45 PM - Post#2784558
Stop running heavy oil. GM specs 5w30 or 10w30, 5w30 was factory fill. You probably don't need the Lucus snake oil either. That could be why your truck only lasted 200K miles.
99 K3500 RCLB
65_Impala
Reg: 12-29-02
01-17-20 04:54 PM - Post#2784563
Pick a top shelf oil and stick with the 5W30 GM recommends. 20W50 is ridiculously thick for your engine.
Synthetics are great, but you have to extend the change interval to get the full value from them. 3k miles is even a rather short interval for today's conventional oils and it's way too short for synthetic oils.
mauryfrench
mauryfrench
Loc: Wylie, TX
Reg: 12-26-19
01-18-20 11:10 AM - Post#2784597
    In response to 65_Impala
Thanks, all.
5W30 conventional it is from now on. I do love the basketball/ping pong ball analogy!
Maury French
Wylie, TX
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-18-20 03:43 PM - Post#2784609
I used 5w30 Kendall GT1 in a 90 I bought new and gave to a grandson after driving it for 18 years and 400k.
Execution time: 0.23 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:04 PM
