Username Post: Axle center section        (Topic#359476)
sz0k30
sz0k30
Loc: Oakland Co., Michigan
Reg: 10-12-08
01-15-20 02:48 PM - Post#2784442
Curious. What material are axle center sections (such as: GM 10 & 12 bolts, Dana's) normally made from? Cast iron or cast steel?
Member #409
01-15-20 04:49 PM - Post#2784446
    In response to sz0k30
Cast steel if it's cast. And you can weld to it if clean enough.
454cid
Loc: West Michigan
Reg: 02-18-12
01-17-20 04:03 PM - Post#2784561
I don't hear of "cast steel" much, so I just looked it up... seems to be a difference in carbon content. The cast iron is greater than 2%, and cast steel is lower than 2%. It sounds like it's basically the same, to me.... sort of analogous to the different grades of stainless or aluminum (each having a bit different properties that lend itself to certain applications). You've also got ductile iron, and grey iron.
I've always heard that the center sections were cast iron, but that could be a generalization.
Why do you ask?
99 K3500 RCLB
scrambldcj8
scrambldcj8
Loc: Belchertown, MA
Reg: 04-06-03
01-18-20 04:30 AM - Post#2784582
    In response to 454cid
I thought it was more of a ductile (nodular) iron as well...similar to the knuckles and/or inner C's. Which are fairly weldable w/pre/post heat and the right rod.
But then if they were all ductile/nodular the 9" Ford "N" dropout center section would be no different form the non "N" dropouts....LOL
https://willmanind.com/what-ductile-iron/
Maybe it's the same/similar.....any metallurgists on board?
Member #409
01-18-20 10:44 AM - Post#2784595
    In response to scrambldcj8
Ductile iron, nodular iron, and cast steel are all same or similar materials. Much stronger and less brittle than cast iron, and weldable.
Execution time: 0.174 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:00 AM
