Username Post: Replacing lug nut studs        (Topic#359468)
Denver56BelAir
Denver56BelAir
Loc: Parker, Colorado
Reg: 01-11-05
01-14-20 12:16 PM - Post#2784386
One of my studs on the rear passenger side broke off. I'd like to replace all ten of them in the rear with a similar stock replacement that is longer. I'm using standard chrome Chevy open ended lug nuts.
Can anyone suggest where to buy replacements that would be around an inch longer?
Not sure how long I can actually go without having to pull the axel to fasten them in place.
Paul
Parker, Colorado
56 BelAir Post, T56, 327, 4:11, Astro custom chrome steel wheels,
http://tinyurl.com/56belair
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
01-14-20 01:19 PM - Post#2784389
    In response to Denver56BelAir
Maybe 1 11/16?
Paul
Parker, Colorado
55MAS
Loc: North Coast, Ohio
Reg: 12-19-01
01-14-20 01:48 PM - Post#2784390
Check out Summitracing.com and jegs.com.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-15-20 05:38 PM - Post#2784450
Moroso has long wheel studs. I bought some aftermarket axles for my 56 Sedan Delivery from Randy's Ring and Pinion, since they're only about 2 miles from me as-the-crow-flies. I believe they were Dutchman at the time; now they sell Yukon as their house brand. Went to install some longer studs I had on hand, and they would't fit, despite being CORRECT for the car (???); they would need a stud with a LOT smaller knurled shank. Went back into Randy's; "you need these special wheel studs". "Well, why did't you sell them to me when I picked up the axles"? Blank face, did't know what to say, but sold me the new wheel studs. So, be SURE you get the correct wheel studs for the axles you have/buy-bought. I am Butch/56sedandelivery.
Edited by 56sedandelivery on 01-15-20 05:40 PM. Reason for edit: No reason given.
01-16-20 08:46 PM - Post#2784517
i would be looking at arp products. if can i would be looking at bigger studs too.
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
01-20-20 11:51 AM - Post#2784735
What product do you suggest Butch/56sedandelivery?
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
01-20-20 11:58 AM - Post#2784736
Do you have to remove the brakes to pull the axels on a stock rear end? If I remember right, I thought I only had to remove 4 bolts on each side to remove the axel.
I need to get the studs pressed out and new ones pressed back in.
Paul
Parker, Colorado
Denver56BelAir
Denver56BelAir
Reg: 01-11-05
01-24-20 02:32 PM - Post#2785092
Do you have to pull the axel to replace the studs? Do you need a press to push them out and put them back in?
Paul
Parker, Colorado
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
01-24-20 07:29 PM - Post#2785116
It seems to me years ago I had a broken rear stud and I know I didn't remove the axle. Probably the brake stuff but that was 50+ years ago. I know we just pounded the old one out with a punch and you just draw the new one in with a lug nut and a BUNCH on washers or some spacer.
57 Bel Air 2dr Ht
327 700r4
55MAS
Reg: 12-19-01
01-25-20 07:29 AM - Post#2785132
    In response to 57tim
Execution time: 0.111 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:34 PM
