Username Post: Engaging 4WD 93 suburban/Auto        (Topic#359465)
opus
opus
Reg: 10-20-04
01-13-20 02:16 PM - Post#2784344
When I yank on the transfer case lever, the light indicator lights up in a few seconds and I have 4WD. I just did that, light went on, then it went off in half a mile. No 4WD.
What does the sequence consist of when I put it in 4WD? I know there is a nitrogen cartridge I believe, on the front axle.
Before I get to looking, tell me where to look and save me some precious time, please.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-13-20 06:40 PM - Post#2784360
    In response to opus
The thermal actuator on the front diff is the first suspicion.
Especially since you said it failed after engaging.
If it has not been replaced it should be upgraded with the electronic version
Old School GM fan FOREVER
Edited by rockfangd on 01-13-20 06:42 PM. Reason for edit: No reason given.
opus
opus
Reg: 10-20-04
01-13-20 06:44 PM - Post#2784361
    In response to rockfangd
Never been replaced.
Hmmm...electronic version? With all the gravel roads I am on, I'd need some convincing.
Never knew there was an electronic version.
tcndeb
Reg: 04-18-04
01-14-20 09:27 AM - Post#2784380
    In response to opus
I switched mine to the manual cable version, and it works very well.
'92 Full Size Blazer
opus
opus
Reg: 10-20-04
01-14-20 09:53 AM - Post#2784381
    In response to tcndeb
Oooo...tell me more.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-14-20 02:49 PM - Post#2784394
    In response to opus
@bowtie44s
Jeff, you did the cable style, too, right? Lokar?
Greg
'00 Explorer XLT 4.0 V6 Auto
opus
opus
Reg: 10-20-04
01-14-20 05:13 PM - Post#2784403
    In response to CowboyTrukr
I went with the motorized version.
Thanks for the input.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-14-20 06:48 PM - Post#2784405
    In response to opus
The electric one is great. No issues there.
There is a cable option, alot more work to do though for more work to use.
If you upgrade to the electric you will likely forget about any issues.
And it does not have the delay of the thermal ones.
Gravel roads wont matter. They cannot be any worse that NY roads
opus
opus
Reg: 10-20-04
01-14-20 08:15 PM - Post#2784406
Good to know. I like manual but the price and work for the cable one....nah.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-14-20 08:29 PM - Post#2784407
    In response to opus
The only benefit I really see is the ability to have 2lo if you did a manual setup.
Can be done with the actuator as well though with not too much work
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-14-20 09:03 PM - Post#2784409
I did the 4x4 posi-lok and hid the red button in the ash tray. I put one in my brother's 95 and it's easier to tuck under the dash out of sight with the new interior.
Jeff
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-14-20 09:06 PM - Post#2784410
The 2 low is nice. The biggest thing is the thermal actuator takes a long time to heat up when it's cold and it WILL fail. It's just a matter of time. It usually decides to fail when you need it most.
The electric ones seem to be more dependable, but I like having 2 low when I'm backing a trailer in a tight spot with my manual transmission.
Jeff
Edited by bowtie44s on 01-14-20 09:11 PM. Reason for edit: No reason given.
opus
opus
Reg: 10-20-04
01-14-20 09:41 PM - Post#2784411
    In response to bowtie44s
Its the wifes rig so I'm not worried about 2 low. Sure enough be easy to do though, just put a switch on the power feed.
Execution time: 0.194 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:28 PM
