Username Post: Gas fill neck seal        (Topic#359464)
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
01-13-20 02:14 PM - Post#2784343
This is the fill neck seal in the trunk. I've checked all the usual sellers. A part number search comes up empty.
Attachment: P1040237.JPG (167.47 KB) 10 View(s)
Tommy
49 Deluxe Sport Coupe, 4.8/4L60E swap in progress, MII IFS, Blazer rear axle, 4 wheel power disc brakes, power steering, air conditioning.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-13-20 03:50 PM - Post#2784348
    In response to tommy49
I think all information relating to inner panel is what you might be looking for.
Attachment: Scan_14.jpeg (146.94 KB) 5 View(s)
1951 Fleetline Preservation
tommy49
tommy49
Reg: 09-28-12
01-13-20 04:43 PM - Post#2784352
    In response to RAM_51
I looked up those numbers, but didn't find a seal. I thought it would be available. I'll just make one. Thanks.
Tommy
RAM_51
RAM_51
Reg: 12-28-02
01-13-20 06:29 PM - Post#2784359
Misunderstood your post...the seal looks very much like the steering column seal. Probably made of closed cell foam rubber...I assume. I created a few seals very similar to what you have there but on the floor shift and E-brake on my '53 6500. I had purchased some 1-1/4" thick foam rubber at a fairly extensive hardware store in Bellingham, WA.
Attachment: IMG_0249.jpeg (2.8 MB) 7 View(s)
tommy49
tommy49
Reg: 09-28-12
01-20-20 05:52 AM - Post#2784708
I made the foam seal and coated it with Plasti-Dip liquid rubber. It works.
Attachment: gas_tank_fill_tube_2.jpg (173.92 KB) 1 View(s)
Tommy
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
01-20-20 01:51 PM - Post#2784746
You guys are bleedin' geniuses!
Dean50
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
01-20-20 04:54 PM - Post#2784767
Good looking seal, way to go Tommy guess I knew you'd do it.
tommy49
tommy49
Reg: 09-28-12
01-21-20 03:52 AM - Post#2784788
    In response to Mike JW
Thanks. It looks kind of crude, but that's the Plasti-Dip. I ladled it on pretty thick,
Tommy
RAM_51
RAM_51
Reg: 12-28-02
02-16-20 10:54 AM - Post#2786658
If anyone is faceing the same situation and does not have access to any closed cell foam, I did find this. It is a 6-1/2" x 9" x 1/2" solvent resistant dense rubber seal / Pad that you cut to size.
LINK:
https://www.ebay.com/itm/VINTAGE-PICKUP-TR UCK-CAB-...
Execution time: 0.063 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:05 AM
