Username Post: Jamco Rear Suspension Problems        (Topic#359460)
jvahila
Loc: Canton Ohio
Reg: 11-07-17
01-13-20 01:23 PM - Post#2784335
I purchased a 3" Rear End lowering kit from Jamco Suspensions. Has anyone had problems with the lower shock mount bracket orientation. I can not get the lower part of the shock to mount correctly. it seems to me the mount is not in the correct location.
01-13-20 01:48 PM - Post#2784337
    In response to jvahila
The lower spring mount is the shock mount/bracket also. My 51 with Posies lowering springs, the shock mount faces rearward, not sure what your issue is here.
Execution time: 0.248 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:41 PM
