Username Post: carpet or mat        (Topic#359453)
Airlifter
Airlifter
Reg: 06-07-15
01-12-20 03:36 PM - Post#2784273
I didn't want to hijack the carpet thread so I will start another.
I am making plans to re-upholster my 51 coupe and would like some advice about the floor covering.
I would kinda like to use an original type rubber mat in the front but I am concerned about the noise. Does anyone know if the carpet would be any quieter than the mat?
I am installing extra insulation everywhere that I can to try to reduce the noise so I don't want to do something to counteract that.
Thanks, Pete
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-12-20 04:28 PM - Post#2784277
    In response to Airlifter
Originally, all '51 Chevrolets [DeLuxe and Special] came with a rubber mat in the front regardless of trim level although the design differed slightly as he DeLuxe models had a simulated carpet insert [also rubber] on the floor board directly in front of the seat [the only exception to this was the Belair. Sometime in 1950 the front floor covering changed from the rubber mat to black carpeting in the Belair models]. The mats all had a jute backing on them while the toe board had about a 1/2" sound board laid onto it. The carpet in the rear which was very thin carpeting with rubber backing also had a jute mat between the carpet and the steel floor. I'd figure that anything thicker than what was laid down originally would afford at least a little better sound deadening.
1951 Fleetline Preservation
Execution time: 0.249 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:15 PM
