Has anyone installed the NAPA clutch kit in their stock set-up? I believe it is the 04-021 lux kit. The throw-out bearing is much shorter due to the raised diaphragm.
The problem is the clutch fork will not easily fit over the bearing. Everything else fits. I could grind a little off the fork, but am hesitant to due that...
NAPA says ti should fit, everywhere else says this kit will not. NAPA part#1104021
I do not care what they tell me about fit. If it does not fit then it is not right. When I needed a kit for the 52 NAPA just ordered me a rebuilt clutch kit and it worked fine.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
