Username Post: 95 5.7 Tbi Suburban runs bad        (Topic#359442)
95tbisuburban5.7
Reg: 01-11-20
01-11-20 10:11 AM - Post#2784183
Hi all,
I have a 1995 Suburban with a 5.7 and Tbi and for a while I have been chasing down a hesitation issue with little success. So far I have replaced spark plugs , wires , distrubuter cap and rotor , fuel filter and egr valve all withing the last 15000 miles. These changes maybe made a slight change to performance but it still hesistates bad. I have also pulled codes from it but no codes come up. I have also checked live data with the scan tool for the 02 sensors and all seems to be functional.The egr valve was not holding preassure too, so i changed that , but still not completely solved. Finally last week , i bought an adapter to test the fuel preassure at the TB and found that when its idleing it is around 9 psi and when i give it some gas underload (in gear) it drops to about 5-6. I know these early tbi systems run at low preassure but is this normal for it to drop that low ? Let me know your toughts. If not what would be your next steps ? Fuelpump? Regulator? Thank you all for your time. Anton
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-11-20 12:54 PM - Post#2784190
    In response to 95tbisuburban5.7
Even though 9-13 is the factory fuel pressure spec, most of us have found that nothing less than 10 is best.
Change your pump.
Greg
'00 Explorer XLT 4.0 V6 Auto
01-11-20 12:59 PM - Post#2784191
Under load the fp should increase to about 13psi, not drop, clogged fuel filter, bad fuel pump, or pressure regulator in the throttle body. BTW welcome to CT. Try to pinch off the return line, may not be able to if all metal. If the pressure does not go up, pump is bad.
Edited by Shepherd on 01-11-20 01:01 PM. Reason for edit: No reason given.
95tbisuburban5.7
Reg: 01-11-20
01-11-20 05:56 PM - Post#2784210
Ok thats what I thought, ill try pinching it off and see what happens, thanks for your input.
95tbisuburban5.7
Reg: 01-11-20
01-11-20 05:58 PM - Post#2784211
    In response to CowboyTrukr
Ok thats good to know thank you
65_Impala
Reg: 12-29-02
01-11-20 05:59 PM - Post#2784212
Fuel pressure is too low. around 11-13psi would be better.
Fuel pressure should not change with load. There is nothing in a TBI system which can change pressure depending on engine load.
95tbisuburban5.7
Reg: 01-11-20
01-11-20 06:11 PM - Post#2784213
Ok , sounds like I need a pump then, what brand would you guys recommend ? What seems to be the best ? Thanks , Anton
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-11-20 08:53 PM - Post#2784220
Definitely time for a pump. Delphi is probably the best brand but AC Delco is good too. I wouldn't get anything besides one of those two.
I find it way easier to slide the bed back than drop the tank. 8 bolts and you can work on it at waist level and it doesn't matter if your tank is full.
Jeff
95tbisuburban5.7
Reg: 01-11-20
01-12-20 06:59 AM - Post#2784235
    In response to bowtie44s
Ok ill go with one of those then. Ill have to drop the tank since im on a suburban platform. Shouldnt be too bad tho. Thanks Anton
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
01-12-20 09:08 AM - Post#2784247
There’s a static ground strap from the tank to the body that sits next to the filler. 7mm screw if I recall correctly. Be careful to find it and remove it before you drop the tank. I didn’t when I first pulled mine. The fuel pump sending unit ground is on the top of the frame rail right near the harness plug. 13mm machine screw. It holds the harness plug in place.
15mm tank strap bolts.
You may find it easier to release the front tank mount by just removing the four nuts from the studs that go through the side of the frame.
Greg
95tbisuburban5.7
Reg: 01-11-20
01-12-20 09:41 AM - Post#2784249
Ok thats good to know thanks for the pointers ill let you know how it goes -Anton
95tbisuburban5.7
Reg: 01-11-20
01-18-20 08:06 AM - Post#2784585
Hi all, just put the new fuel pump in it and I immediately noticed a difference. It fires up much faster now , the hesistation is gone and it runs great. Thanks for all your help. -Anton
Edited by 95tbisuburban5.7 on 01-18-20 08:07 AM. Reason for edit: No reason given.
Execution time: 0.234 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:10 PM
