Username Post: 2 guys        (Topic#359433)
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
01-10-20 01:23 PM - Post#2784136
Some how, two guys were trying to cross a desert,
Yeah it was hot, no water a lot of sand and all the typical stuff,
But.........
Some how they ran across a camel,
They figured the camel could help them cross the desert,
But.........
The camel was as thirsty as they were,
So for days they trudged along,
Finally the camel had stopped and layed down,
No matter how much they tried to pull the camel he would not budge.
As usual the camel was able to talk, the camel said he refused to walk any further as they were going the wrong way.
Stop me if you have heard this one.......
VC56S 2 door Sedan, 39 Years
Edited by Bad56Sedan on 01-10-20 01:23 PM. Reason for edit: No reason given.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-10-20 01:26 PM - Post#2784137
    In response to Bad56Sedan
So, one of the two said he too was to tired and thirsty to keep going and naturally he agreed with the camel,
So the other guy said he would go ahead and find the oasis,
He was gone for several days,
He found the oasis!
Stop me if you heard this........
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-10-20 01:36 PM - Post#2784138
The one guy encouraged the other guy to keep walking it was just over the next pile of sand,
They had to had the camel to make it out the other side,
So they both pulled and pulled the camel,
Finally the camel said you two better be right and got up and started walking,
After about a day or so they made it to the oasis,
They both jumped in and drank and drank,
Yet the camel just stood there,
One guy pulled the camels head down and the camel refused to drink,
One tried cranking the camels tail,
Finally one guy suggested to the other guy that if he sucked on the back end of the camel he could draw the water into the camel,
So after continued trying finally the guy trying to draw the water through the camel stopped looked around with his face covered in........he told the guy holding the camels head in the water....
HEY MIND LIFTING HIS HEAD UP A BIT, I THINK IM SUCKING MUD!
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-10-20 02:01 PM - Post#2784140
BOOOOOOOOOO!!!!!!!
and BOOOOO!!!!!!
Edited by grumpyvette on 01-10-20 02:01 PM. Reason for edit: No reason given.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
01-10-20 02:11 PM - Post#2784141
    In response to grumpyvette
Lol,
Wait for the next two guys!
This is a break doing a cam swap,
Got the new one piece pan gasket, finally got that done,
Any golfers out there!
Edited by Bad56Sedan on 01-10-20 02:13 PM. Reason for edit: No reason given.
TAT_2
Member #26 "19th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-10-20 11:56 PM - Post#2784163
2 GUYS DEPT STORE
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
02-22-20 04:49 AM - Post#2787033
    In response to TAT_2
BRAVO TAT!
It's all good. mostly
Execution time: 0.131 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:28 PM
