Username Post: Garnish Molding Screws for 54        (Topic#359422)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-09-20 03:10 PM - Post#2784074
Does anyone have any experience with these "screw kits" from NCA? I was pretty disappointed with the selection at the local hardware store.
https://www.nationalchevyassoc.com/garnish_molding...
Thanks,
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
2blu52
2blu52
Reg: 03-12-02
01-09-20 03:54 PM - Post#2784076
    In response to dsacton
For 15 bucks would by them just to see if they worked!
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
mahlmann
mahlmann
Loc: Las Cruces, NM
Reg: 01-20-11
01-09-20 04:09 PM - Post#2784078
    In response to 2blu52
I have purchased 2 sets of these screws and consider then a real bargain. The quality is very good. However, if the screw hole is enlarged or stripped, you will probably need a larger diameter screw.
Good luck with yours!
Mike Ahlmann
Las Cruces, NM
'50 Tin Woodies (two) Ramon and Willard
'58 Impala Sport Coupe
'69 El Camino SS-396
'07 Ford F150 to haul parts for above
'16 Ford Explorer 3.5 EcoBoost - Red Rocket
2blu52
2blu52
Reg: 03-12-02
01-09-20 05:29 PM - Post#2784084
    In response to mahlmann
In the past when a trim hole was larger than the appropriate screw I just stripped some copper wire and fed it into the hole and then put the screw in, works fine.
THOMAS JEFFERSON
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-09-20 07:30 PM - Post#2784088
Thanks for the information. And 2blu---what a great idea! I will give that a shot.
Scott Acton
eplantage
Loc: Southern MN
Reg: 03-15-04
01-10-20 04:26 AM - Post#2784111
I have purchased several different screw kits from them when I was putting my sedan delivery back together. OEM type fasteners and clips are just not to be found anywhere. I've been very satisfied.
Age: 66 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
Airlifter
Airlifter
Reg: 06-07-15
01-11-20 05:54 AM - Post#2784172
    In response to eplantage
Glad you asked the question. I was looking for screws for my '51 coupe.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
Execution time: 0.243 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:30 PM
