Username Post: What size wheels for disc brakes?        (Topic#359421)
VintageChevyIron
VintageChevyIron
Loc: Rochester, WA
Reg: 01-01-20
01-09-20 02:57 PM - Post#2784072
Sorry if this have been covered, tried searching but still figuring that function out.
When switching to disc brakes, what is the smallest size wheels required to clear the calipers?
I am not a fan of the really big wheel with small tire sidewall look, so the smaller the better.
My plan for now would be a coke bottle style wheel, like a Cragar SS style.
Currently my 57 has 14' reverse chrome, baby moons. Will I need to go at least 16" or am I stuck with something in the 17" or 18" size range?
Thanks for any guidance.
It is better to be consistently incorrect than inconsistently correct...
01-09-20 04:36 PM - Post#2784080
    In response to VintageChevyIron
Just did the conversion on a 55, 15" wheels, we had to nip some metal off the corners of the calipers, using 11" rotors.
01-09-20 06:07 PM - Post#2784086
You can use 14" wheels with 11" disc brakes, if they are made for discs. I have 14x7 wheels from a later model Camaro and discs.
VintageChevyIron
VintageChevyIron
Loc: Rochester, WA
Reg: 01-01-20
01-09-20 09:19 PM - Post#2784096
    In response to acardon
Thank you so much, that is very helpful.
warpwr
warpwr
Loc: Santa Clara, CA
Reg: 04-11-06
01-09-20 10:53 PM - Post#2784105
Wheel Vintiques makes stock looking wheels that clear disk brakes.
https://www.wheelvintiques.com/wheels/classic/67-s...
Vaughn
56 Delray 327, 5 spd
VintageChevyIron
VintageChevyIron
Loc: Rochester, WA
Reg: 01-01-20
01-11-20 12:07 AM - Post#2784165
    In response to warpwr
Great link, thanks much!!
craig32
Loc: PA
Reg: 08-05-07
01-12-20 04:36 AM - Post#2784228
I have a longer "show your work" version, but the short version is a 14" wheel will clear disc brakes.
66 Impala (almost done!)
56 Stepside shortbed
55 Bel Air sedan
81 Corvette
02 Monte Carlo (bought new)
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
02-21-20 01:45 AM - Post#2786978
    In response to craig32
Play it safe - some calipers have rough casting material on the top of the part that will gouge the inside of the 14" wheel - double check this area!
I'd rather be thorough than vague
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-21-20 07:38 AM - Post#2786993
This pic is simply a visual. It's my '63 with 15" Cragar SS, p215x70r tires.
It does not have disc, but they could be added (not by me). I don't race, drive in steep hilly areas, pull a trailer, nor drive in rush hour traffic. I'm not concerned about heat produced fade so I don't need them. I do drive OFTEN and ANYWHERE; highway, country road, suburban streets, etc.
IF you decide on the Cragars, recommend the direct drilled versions. I don't like the one size fits all wheel.
Hope this is helpful.
Pete
Attachment: IMG_0430.jpg (1.36 MB) 15 View(s)
VintageChevyIron
VintageChevyIron
Loc: Rochester, WA
Reg: 01-01-20
02-21-20 10:54 AM - Post#2787005
    In response to japete92
Thanks for the replies.
That drop-top looks sweet!!
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
02-22-20 08:03 AM - Post#2787044
You wouldn't even notice the 1" difference between 14 and 15" wheels as far as looks go. I second the direct drilled Cragars vs unilug. Don't ask how I now.
57 Bel Air 2dr Ht
327 700r4
Execution time: 0.054 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:01 AM
