Username Post: Frame off convertible questions        (Topic#359417)
C. Anothalevel
Reg: 03-12-19
01-08-20 07:06 PM - Post#2784022
Ok so I passed on the burnt convertible and found one the guy has taken off the frame. I was under the impression you should always brace a convertible before taking it off the frame. Is a rust free car solid enough that having it on a body lift won’t be having the thing shift at all? I’m worried I saw gaps in the panel alignment from him doing so. Can anyone chime in on this?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
01-08-20 07:31 PM - Post#2784024
    In response to C. Anothalevel
All convertibles require the doors to be removed and braced jamb to jamb on both sides. Some add internal bracing welded to the internal front kick panel steel and rear 1/4 panel were the rear windows are accessed.
Finally poor structural condition convertibles should have x braced steel welded to the top of the windshield frame and the back seat area.
I have pictures of all the braced types I have listed here from 62 convertibles were I had local body shops do restoration work on my convertibles.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
http://paulstensland.com
C. Anothalevel
Reg: 03-12-19
01-12-20 03:41 PM - Post#2784274
    In response to pvs409
So what do you do with a car that has full interior and stuff? His car is off the frame with all the interior intact and he was just working on the frame and belly of car. I advised him against it but he says it’s just fine and said something along the lines of how do you think they mounted them to the frame at the factory. Can anyone else chime in and lemme know of any undue stress on this body and such.
junky
Loc: Northeast CT
Reg: 06-27-10
01-12-20 05:57 PM - Post#2784284
The body was empty when it was assembled to the frame at the factory, and there were no doors, interior, dash, or anything else for that matter, and it was handled by very specific lifting points. Now, if the body that he has off the frame is as solid as the day it was built, and you remove everything from the body, including the trunk lid and doors, with new bushings, it might just work out OK. It all depends on how your luck is running. When I worked at a shop that rebuilt wrecks, we would lift the bodies up using 4x4 timbers, and set the timbers on tall jack stands. Roll out the old frame, and roll under the new frame. Being we had to do everything manually, the interiors were always out of the cars, but the doors were left on. 4 rolling jacks under the timbers, with one person on each corner. Jack it up as high as we could get it, then lower it onto jack stands, and take another "bite" with stacked wood on the jack saddles until it was high enough. It was all about the boss having lots of experience. We followed his instructions, and it always went well.
Execution time: 0.227 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:15 PM
