Username Post: 235 Rochester B or 261 Rochester B?        (Topic#359411)
01-08-20 08:50 AM - Post#2783985
I recently bought a 261 engine, which sat in a barn since 1986. It has a stock manifold and a Rochester B on it. I intend to sell the Rochester carb on that auction site, but is there any way to tell if it came on a 261?
The base casting number is 7003536-C-33.
I don't want to open it up, but if necessary I can do so.
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-08-20 09:49 AM - Post#2783991
You sure it isn't 7003538? I see that a 55-58 261 would be cast 7002128 or 547005140 for 54-55 261, depending on application.
1951 Fleetline Preservation
01-08-20 10:25 AM - Post#2783992
    In response to RAM_51
No, it's clearly 7003536. I just took it out into the sunlight to see. Thanks Ram. I figured a 261 carb would be too good to be true.
The engine is a 1959 261.
RAM_51
RAM_51
Reg: 12-28-02
01-08-20 04:13 PM - Post#2784007
I don't see that casting number mentioned in the GROUP section 3.729. I am using a 1933-1961 Chevrolet Chassis Parts and Accessories Catalog. Maybe it appears in earlier parts catalogs.
01-08-20 04:20 PM - Post#2784010
Here's a picture.
drtyler
Loc: Georgia
Reg: 05-06-10
01-08-20 04:41 PM - Post#2784011
54 catalog, appears with carbs for 54 car with PG (7005922), 50-52 cars with PG (7003526), 54 cars & 54 Comm (7005921).
Edited by drtyler on 01-08-20 04:44 PM. Reason for edit: No reason given.
01-08-20 05:30 PM - Post#2784013
    In response to drtyler
Wow. Thanks Ram.
RAM_51
RAM_51
Reg: 12-28-02
01-08-20 11:38 PM - Post#2784031
Credit where credit is due...that was drtyler. I thought you meant the number was cast into the Throttle body....that's what I thought you meant by "base". It's actually on the bottom side of the "float bowl".
01-09-20 07:37 AM - Post#2784043
Oops. Had a senior moment there.
Thanks Dr. Tyler!
Execution time: 0.229 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:25 PM
