Username Post: trans dipstick /filler length on a 2004r        (Topic#359407)
tikiwagon
tikiwagon
Loc: dorset, england
Reg: 04-23-04
01-07-20 11:54 AM - Post#2783931
Hi i am converting from a Powerglide to a 2004r trans on my 59 and need to know the length of the dipstick/filler tube as where i bought it from gave me a universal "fitzall" tube and stick(part K35999U) in the instructions it says cut 1 1/4" from the top of the tube for 200 trans but i have been told by a couple people this is not right, I don't want to cut and have my fill levels wrong
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
01-09-20 04:09 AM - Post#2784034
    In response to tikiwagon
Do you have any idea if a 700-R4 is the same length? I can't get to the filler tube at this time of the year but I can measure my 700-R4 dipstick if it will help. I don't have a 200-4R.
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
tikiwagon
tikiwagon
Reg: 04-23-04
01-09-20 10:15 AM - Post#2784054
Thanks but the 700 is a different part number according the manufacturers instructions
Hards..60
Hards..60
Loc: Northern Ontario,Canada
Reg: 10-20-07
01-09-20 11:13 AM - Post#2784060
Hi David
I've recently installed a 200-4r into my '60 Impala. The transmission comes from a 1987 Monte Carlo SS so hopefully it's the same.
I've attached pictures that may help you with your installation.
The overall length of my dipstick tube is 26 inches.
I live in Canada and believe it or not I don't own a metric tape measure....
If this isn't clear enough for you ask for more and I'll do my best.
Attachment: HPIM1391.JPG (1.49 MB) 3 View(s)
My transmission.
Attachment: HPIM1397.JPG (1.53 MB) 2 View(s)
Length of dipstick from this point.....
Attachment: HPIM1399.JPG (1.69 MB) 2 View(s)
Tip of dipstick showing overall length.
Attachment: HPIM1400.JPG (1.58 MB) 2 View(s)
This shows how far past tube dipstick protrudes and enters transmission opening.
Roger.
1960 Impala 2dr hard top - 348 tri
tikiwagon
tikiwagon
Reg: 04-23-04
01-10-20 02:48 PM - Post#2784149
    In response to Hards..60
Thanks for your great reply, Was your tube/Dipstick from Fitzall as mine is because they say cut 1 1/4" just from the tube(when installed in the car the tube sits almost flush with the top of the firewall) so looks really long
Hards..60
Hards..60
Reg: 10-20-07
01-10-20 04:01 PM - Post#2784152
The dipstick came with the transmission from the builder/seller.
If I were to cut anything off the tube, then the bracket that is bolted to top of the transmission (support bracket??)would not line up with the holes....so be careful when considering any cuts.(see picture of transmission)
The tube is also high on my firewall....it is what it is.
Roger.
Edited by Hards..60 on 01-10-20 04:04 PM. Reason for edit: No reason given.
Hards..60
Hards..60
Reg: 10-20-07
01-11-20 05:52 AM - Post#2784171
Dave
I may have had a senior's moment when I replied to your thread yesterday.
The cutting of the tube makes sense, since it could provide a more accurate reading when checking the oil level in the 200-4r.
I thought of this after looking at the picture where the length of dipstick that protrudes from the tube on my transmission looks sort of short.
So now we both have a problem. Thanks for bringing this up here on CT....now let's see if we can figure this out together.
Roger.
tikiwagon
tikiwagon
Reg: 04-23-04
01-11-20 02:50 PM - Post#2784200
Okay i will measure mine tomorrow and compare to your one, But the instructions say cut of the top of the tube, But i have been told not to do this the reading wont be right
Hards..60
Hards..60
Reg: 10-20-07
01-11-20 03:13 PM - Post#2784202
David
Could you post a picture of your dipstick and dipstick tube? I noticed that the installation instruction say something about a "clip". I'm curious as to what that is.
Roger.
Hards..60
Hards..60
Reg: 10-20-07
01-15-20 05:23 AM - Post#2784416
David
The only thing I can think of would be to fill the transmission to specification and then check the level....according to your current dipstick length.
If it doesn't show full, then cut the tube until the desired reading is achieved.
Roger.
tikiwagon
tikiwagon
Reg: 04-23-04
01-16-20 10:42 AM - Post#2784480
Hi Roger yes that is a good idea, My tube is approx 28" long but a little difficult to measure when it is in the car and fairly tight to the firewall
Execution time: 0.184 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:03 PM
