Username Post: Whats Everybody Using For A Grease Gun?        (Topic#359393)
Blueseasons
Reg: 10-13-11
01-06-20 02:12 PM - Post#2783834
A few years ago I tossed my full-size grease gun when I sold my 52 PU. Stupid move. I hadnt bought this Chevy yet. I have been through 2 of those smaller hand sized ones thinking one might be better than the other and they are both a nightmare to use. They waste grease they are messy and time consuming. I like to keep everything lubed on my 88 k1500 but I dread doing it. Back in the day any Service Station would grease a front end up for a few bucks but not anymore.
Senior Moderator
01-06-20 03:31 PM - Post#2783839
    In response to Blueseasons
I have a love-hate relationship with grease guns. I asked years ago in the "Garage" section and despite some good responses, I still ended up buying a POS because I was in a bind and needed to do some maintenance.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-06-20 04:22 PM - Post#2783845
I use a full size gun,with the one hand trigger,so I can use my other hand to hold the hose connection on the fitting.
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-06-20 06:22 PM - Post#2783859
    In response to Lead sled
I have love and hate as well.
So irritating.
The Dewalt battery operated one seems to be ok. Less work for the hassle, but higher price though
Old School GM fan FOREVER
Blueseasons
Reg: 10-13-11
01-06-20 06:27 PM - Post#2783863
I'm not sure which one you are talking about. I had one like this for years and it worked fine. https://www.amazon.com/FIXSMITH-Cartridge-Pr ofessi...
I tossed it and bought one of these thinking I was moving up and Its just a time consuming mess. Grease squirts out the bottom around the plunger. It works for a short time, then air gets in the cartridge and I have to bleed it. Only a fraction of the grease gets used. The rest of it ends up everywhere.https://www.amazon.com/Plews-Edelmann-30-132 -Lubrimatic-Multi-Purpose /dp/B000G76OKW/ref=sr_1_8 2?hvadid=3527198659&h vbmt=be&hvdev=c&h vqmt=e&keywords=greas e+guns&qid=1578363788 &sr=8-82
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-06-20 06:33 PM - Post#2783865
My gun like your first one still works great.
Takes 2 hands or something to hold it though. But effective.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-07-20 07:20 AM - Post#2783910
Let me rephrase it. It looks something like this one ( pistol grip)
https://www.amazon.com/UTOOL-Working-Coupler -Exten...
Blueseasons
Reg: 10-13-11
01-08-20 07:05 AM - Post#2783975
I see that one has a mechanism for releasing air pockets. Thats my biggest issue. Will look into it.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-08-20 07:07 AM - Post#2783976
Way more expensive but this actually makes greasing fun.
https://www.amazon.com/DEWALT-DCGG571B-20-vo lt-Lit...
Jeff
454cid
Loc: West Michigan
Reg: 02-18-12
01-08-20 03:00 PM - Post#2784002
    In response to bowtie44s
I don't care about it being electric (it would be dead when I wanted it), but I do like that long hose. My manual grease gun has a hose that's about a foot long and it's too short... I end up having to old the gun up and out while trying to pump it, and keep the nozzle on the zerk.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-08-20 08:09 PM - Post#2784027
    In response to 454cid
They are lithium ion batteries. They don't discharge setting on the shelf. I have dozens of those tools and 12 or 15 batteries so I always have plenty charged. The impacts are great. I never use my air impact anymore.
Jeff
grumpyvette 73
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-09-20 04:06 AM - Post#2784032
Lincoln Lubrication 1134 Heavy Duty Pistol Grip Grease Gun with Whip Hose and Rigid Pipe
Edited by grumpyvette on 01-09-20 04:07 AM. Reason for edit: No reason given.
Silverado Kid
Loc: Jackson California
Reg: 07-26-16
01-09-20 11:13 AM - Post#2784059
I bought the DeWalt 20 volt Max grease gun a couple of years ago and I would never go back to air or the manuel guns. It has a positive lock-on nozzle to go onto the zerk fitting and the rest is a piece of cake. A few bucks for sure but if you are doing your own grease and lube jobs you owe it to yourself to make the job easier and more enjoyable. And the L-ION batteries last a long time between charges.
gkralik3645
gkralik3645
Loc: omaha
Reg: 12-05-13
01-10-20 06:56 AM - Post#2784119
    In response to Silverado Kid
The one I use was rescued from my dad's farm sale in 1974. It uses tubes of grease. It has a hose about a foot long and has a pistol grip. I guess it is about 60 years old and works great.
George
Execution time: 0.134 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:26 PM
