Username Post: Sometimes starter won't start        (Topic#359391)
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-06-20 02:52 PM - Post#2783831
Every now and then I go start my 60 and it doesn't start the starter. All the lights and everything else lights on but it doesn engage the starter. I'll disconnect the battery and sometimes it starts right but and sometimes I have to wait a few minutes.
I'll drive it after it starts and it'll start right up again. It has a new ignition switch and I checked the connections and ground. I don't know what to check next.
62sedan
62sedan
Loc: Above the red Texas dirt
Reg: 08-12-02
01-06-20 03:47 PM - Post#2783836
    In response to Eth727
...... It has a new ignition switch.....
Probably one of those crappy, suspect quality Chinese POS knock-off items.
Chuck
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-06-20 04:23 PM - Post#2783837
    In response to 62sedan
It's a NOS one.
01-06-20 04:41 PM - Post#2783841
Is it an automatic? Bad neutral safety switch.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-06-20 05:24 PM - Post#2783846
Could be a bad ground connection somewhere.
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
airsurf
Reg: 07-27-12
01-06-20 05:43 PM - Post#2783849
For years my starter wouldn't turn occasionally after it was hot. I would then use a wire and jump from the battery to the starter. Finally someone suggested that the firewall connector might be corroded. That was it. Cleaned it up and now it always starts.
benignbrent
Reg: 11-28-19
01-06-20 09:37 PM - Post#2783878
I got my starter repaired by Karl Knudsen Automotive's mechanics. Their service is amazing and they got to fix my car within a reasonable price! If you ever need a car mechanic in Sydney, Karl Knudsen Automotive is the place to be.
01-07-20 07:36 AM - Post#2783904
does it click? starter solenoid would be my 1st check.
bowtieollie
Member #3 ChevyTalk Subject Matter Expert
bowtieollie
Reg: 12-06-99
01-07-20 12:42 PM - Post#2783929
How old is this starter?
was it a rebuilt starter?
I am willing to bet it is an intermittent solenoid contact
Bowtieollie
Chevytalk.com Moderator
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-16-20 02:12 PM - Post#2784486
    In response to bowtieollie
So I installed a new neutral safety switch and it still has the same issue as the old switch. I started it in neutral and that worked. I'm not sure how old the starter or solenoid is but it looks fairly new.
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
01-16-20 05:13 PM - Post#2784500
You can buy new starters and solenoids that don’t work, so looks don’t count.
Member #2194
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-17-20 02:46 PM - Post#2784549
Please clarify, cuz it makes all the difference in diagnosing your problem:
Are you saying it will always start in neutral, problem resolved if in neutral?
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-17-20 03:04 PM - Post#2784551
Ollie
So nice to see a post from you again! Its been a while. We have missed your good advice and depth of experience. Hope you are doing well.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-17-20 03:11 PM - Post#2784552
    In response to JayChicago
I've only started it in neutral once. So I installed a new neutral safety switch. It worked for a few days until yesterday. I decided to shift it to neutral and giving it a try. It started.
I got home and turned it off. Started it in Park. It started. I tried it again in park. It started. I don't know what is going on.
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-17-20 08:03 PM - Post#2784568
Ok, it does sometimes start in park, so that doesn't tell us the neutral safety circuit is the problem. But just to rule it out, next time the starter fails to crank, move the shift lever up some, and also down to neutral, just to see if that movement changes anything.
When it fails to crank, does it make any noise? No clicking sound?
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-18-20 01:39 AM - Post#2784580
Yeah no sound or clicking. The neut switch is brand new. I'm tempted to replace all the wires going into the neut switch and see if that will fix it.
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-18-20 09:40 AM - Post#2784587
I wouldn't do that. Not likely anything wrong with the wires themselves, and doing additional work now may just confuse the issue, add another layer of possible problems. And we don't know the problem has anything to do with the neutral safety circuit. As BowTieOllie said above, problem may well be with the solenoid on the starter. He asked question about that, didn't see a reply from you on that.
You said you recently replaced the ignition switch, and now replaced the neutral safety switch. Was this intermittent no-crank issue going on before you replaced these things?
One wire-related thing you could do is clean the main wire harness connection on the firewall. This is a common weak point with these cars. It is a big black wire connector with multiple wires, on the engine side of the firewall. It makes the connection between the electrical stuff on the dashboard to the electrical stuff in the engine compartment, including the starter solenoid. Not sure about the '60, but it probably is located under where the steering column comes thru the firewall into the engine bay. Difficult to get to. If you can get that old connector separated, you could clean both male and female sides with electrical contact cleaner. That could solve your problem if that's where the problem was. But we don't know that yet. We're just stabbing at this, we don't know where the problem is. It would be nice to have some more clues.
59cheviac
Loc: the sunshine state
Reg: 10-31-03
01-18-20 01:27 PM - Post#2784601
Listen to Ollie! Darn near every older V8 Chevy I owned had this problem, and it almost always was the starter solenoid. They tucked the thing right under the exhaust manifold where it gets baked quite regularly, and this destroys its life expectancy. There used to be a kit available out there to use an older Ford fender mounted solenoid relay to help with this problem, but I haven't had any reason to look for one in quite a few years. People have fashioned heat shields from various materials also, probably with varying degrees of success.
I always carried a long thin screwdriver with me so I could jump the contacts at the solenoid in a pinch, but on the bigger motors, like a 348, it was a challenge.
Edited by 59cheviac on 01-18-20 01:29 PM. Reason for edit: No reason given.
59cheviac
Reg: 10-31-03
01-18-20 01:35 PM - Post#2784602
    In response to 59cheviac
https://www.tuffstuffperformance.com/i-24486449-ho...
Here's an example of the kit I mentioned.
DonSSDD
DonSSDD
Reg: 08-21-01
01-19-20 05:22 AM - Post#2784639
Usually a bad solenoid will give a warning with clicking when the starter is engaged. You should try this when it won’t start- put the car in neutral and with the starter engaged, wiggle the shifter, if the starter rolls the engine over, it’s just an alignment problem with the neutral safety.
Try this and report.
Member #2194
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-19-20 01:42 PM - Post#2784671
    In response to DonSSDD
Yes this intermittent starting issue has been going on since I've owned the car. It's almost been a year. In fact when it arrived off the truck the driver couldn't get it started. The previous owner provided me with a new solenoid. I haven't replaced it because the exhaust I put on makes it a pain to remove the starter. I did clean a plug on the firewall that is linked with the heater fan which was dirty and now the fan works.
I have had bad starters in other cars and it would click.
This issue there isn't clicking. It's like there's no power going to it when it acts up.
Eth727
Eth727
Loc: San Diego
Reg: 04-17-19
01-23-20 07:51 PM - Post#2785014
Today I went to start it and it did it again. I moved the shifter to neutral and nothing happened.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-24-20 08:09 AM - Post#2785057
Have you tried 'jumping' the battery cables (both + and -, individually) to see if one, or both, is causing an intermittent break in the circuit?
I'd start with the - and run a 'jumper' from the battery post to the engine block/water pump. Try and start the car and see what happens. Ditto with the + except connect from battery post directly to starter.
Doesn't cost anything and (if nothing else) may eliminate a couple of possibilities.
IF new cable(s) are needed, I recommend replacing with 2 gauge. The GM 6 gauge is more sensitive to engine compartment heat (which increase resistance).
Just a recommendation.
Pete
JayChicago
JayChicago
Loc: Chicago
Reg: 01-03-13
01-25-20 11:48 AM - Post#2785144
    In response to japete92
I don’t think problem is in the main battery cables. Original post says when problem occurs lights and everything else works. If enough current is getting thru for lights, horn, etc,, should be enough for the solenoid to click. He has no noise.
ETH, here’s another simple test you can try on the neutral safety switch:
While holding key in the start position, move gear selector up and down thru all the positions. (may activate in R or D but not in P or N, f it’s out of adjustment)
As was said above, typical solenoid failure will produce the clicking noise but not activate the starter motor. But maybe it can be a bad solenoid with no clicking? I don’t know. Have you guys ever experienced an intermittent solenoid failure with no noise? Remember this is an intermittent problem; sometimes
starter does work.
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-25-20 02:40 PM - Post#2785149
starter does work.
Because the problem is intermittent, the starter circuit is seeing SOMETHING(S) creating an 'opening' of it intermittently. Or, something(s) intermittently creating enough 'extra' resistance to cause the 'failure' to start. The former would not 'click' the solenoid, the latter may, or may not, depending on the severity.
Also, on my '63, the wire from the battery that feeds juice to lights etc, runs from the + post to the horn relay and then to the voltage regulator via a 8 gauge (I think) wire. It is separate circuit from the from the starter (they do share the same battery connector). IF this car is similar, it's quite possible for the starter to not get juice and the rest of the car be ok.
I think it is reasonable to look for defects (likely 'mechanical') in the 'wires', or their connections/connectors. Anything in the starting circuit is possible. Frayed strands inside the 'wire' insulation (that when the wire' flexes/moves )may cause intermittent 'disconnect'; insulation defects causing exposure of the wiring strands to intermittent 'shorting', are among the possibilities (emphasis on 'possibilities').
Not saying the wiring IS the problem, I do not know what the problem(s) is. The main battery + and - cables are where I would start because they are so easy to check.
REAL 'electricians' (not me, although I do know the basics of circuits) would measure voltage/current. Me? If I think a switch (or an accessible section of wire) needs 'checking', I 'jump' it. Take it out of the circuit. See what happens. Maybe not the best 'test' but it's what I know how to do.
Just trying to be helpful
Pete
Edited by japete92 on 01-25-20 03:20 PM. Reason for edit: No reason given.
Execution time: 0.172 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 AM
