Username Post: Trim rings on Rally Wheel...        (Topic#359390)
70BelAirHT
70BelAirHT
Loc: Qc, next to Maine Border
Reg: 06-09-03
01-06-20 02:20 PM - Post#2783828
Hi guys,
I want to buy new trim rings for the rally wheels I have on the Bel Air. Code on the wheels (FW) says it's 15x7 for 71 and up any models but now how can I know for sure the model for the trim rings? They sells so many different models that I can't figure out wich one is the right one. 3'' deep, 2¼'', how do you get that measure? Thanks for the help, yeah I know, it may not be THE place to get my answer. But I guess any of you may know the answer.
Mathieu Bélanger
Québec, Canada
1970 Bel Air HT 2 doors 350 Sport Coupe(frame off resto)
1970 Caprice HT 2 doors 454
2008 Nissan Quest SE
hemiguy
Reg: 09-11-18
01-07-20 10:47 AM - Post#2783924
    In response to 70BelAirHT
Hi.
I have a 68 Impala with 14 inch rally wheels. I found a set of new stainless trim rings on ebay that fit and look nice. Not original, but look fine.
I just measured from the rim edge to the center to get the size.
I think these are the ones:
https://www.ebay.com/itm/15-NEW-Stainless- Steel-Be...
Good luck,
70BelAirHT
70BelAirHT
Reg: 06-09-03
02-18-20 09:18 AM - Post#2786791
    In response to hemiguy
Here is finnaly an answer from someone at Classic Industries:
''The way you measure the depth is you have to lay the trim ring on a flat surface. You would then put a ruler or measuring tape on the inside of the trim on the flat surface going vertical and measure to the inner lip of the trim ring.''
Now I know how to measure theses rings.
Mathieu Bélanger
Québec, Canada
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
04-24-20 05:42 PM - Post#2792006
The Trim ring should go all of the way to wheel disc. Meaning there should be NO GAP between the inside edge of the trim ring and wheel disc where the slots are located.
    1967 Chevrolet Impala SS convertible 327 - Ermine White C1 - VCCA Senior Award
    1967 Chevrolet Impala SS Sport Coupe 396 - Marina Blue FF - personal "barn-find" lol
N_V_US_67
Loc: Brisbane, Australia
Reg: 05-21-15
05-04-20 05:42 PM - Post#2792786
Hello all,
I found this the other day while looking for the rims I have on my 67 and came accross the trim rings that I need if I ever replace mine its on the gmpartswiki site as follows.
http://www.gmpartswiki.com/getpage?pageid=50215
9796696 15x7jk sized at 2 and 3/8ths wide and 16 and 5/8ths OD for 1970 Pass.
Hope this helps.
Cheers,
Chris.
1967 Chevrolet Impala SS 2 Door Coupe
327 V8, Aluminum Powerglide, 12 Bolt
Butternut Yellow
Gold Interior
Tilt Column
Power Steer
Power Disk Brakes
Air Conditioning
Bucket Seats With Console
All Original
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
05-05-20 08:08 AM - Post#2792823
    In response to N_V_US_67
Awesome find, Chris! Thanks for posting this.
Execution time: 0.107 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:13 PM
