Username Post: ethanol and gas-drier        (Topic#359385)
Stinky
Loc: Whitewater, CO
Reg: 05-25-01
01-05-20 11:17 PM - Post#2783791
The gas gage on my truck (a Nissan) went and I ran out of gas. It showed almost 3/4 on the gage.
I thought that I had frozen water in the lines, or at least thought that it was a possible problem.
My buddy says that I could put a gas-line drier (Methanol) in it. I says, but I've been using ethanol gas in it, isn't that enough?
As a side point, when I put the drier in, you could hear it hitting the bottom of the tank. When I put a gal of gas in, it started right up.
So, is Ethanol enough?
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-06-20 07:56 AM - Post#2783809
    In response to Stinky
Ethanol will draw in moister from the atmosphere,so go to a non ethanol gas or keep using the "gas dryer".
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
01-06-20 01:40 PM - Post#2783830
Read thru this article
https://www.bellperformance.com/blog/4-things-you-...
Execution time: 0.065 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:23 AM
