Username Post: Installing seat belts in a 57 big window        (Topic#359383)
Vijay
Vijay
Reg: 09-06-04
01-05-20 08:31 PM - Post#2783778
Anyone have suggestions on the easiest way to install belts?
I’d like lap belts at the very least, but shoulder ideally...
monty56
monty56
Reg: 04-26-04
01-06-20 09:43 AM - Post#2783811
    In response to Vijay
If you look at the pix in my sig you can see how I installed the "nut" in the pillar. It came from Julianos. I would highly recommend you use the "nut plates" under the floor also from Julianos.
Monty
2001 Chevy Suburban 2500
2009 Saturn Vue w/20's
Monty's 56 Truck
Avatar is my Truck
unclebrad
unclebrad
Reg: 03-12-19
01-11-20 12:58 PM - Post#2784187
this should help:
http://www.bobshotrods.com/howto/3-point-seat-be lt...
"55 Cameo w/409
Vijay
Vijay
Reg: 09-06-04
01-27-20 06:15 AM - Post#2785262
    In response to unclebrad
Thanks. Finally got the truck yesterday. After I get the safety done, I'll have it at home to do these jobs.......
The problem is that it's the big back window version and I'm not sure there's room to drill, but I'll certainly assess the situation and post results.
monty56
monty56
Reg: 04-26-04
01-27-20 09:18 AM - Post#2785276
Mine is the big window and there was room for the "nut" from julianos.
Monty
Monty's 56 Truck
Avatar is my Truck
Vijay
Vijay
Reg: 09-06-04
01-29-20 11:10 AM - Post#2785410
    In response to monty56
I can't see to get to your link. Even after I bypass the UNSAFE warning, the link is bad. Is there another?
Definately interested in putting it in........
Thanks!
Vijay
Vijay
Reg: 09-06-04
01-29-20 11:32 AM - Post#2785411
Did you have to pull the interior panels off to fish up between the back window and the B pillar?
Easily done?
monty56
monty56
Reg: 04-26-04
01-30-20 09:28 AM - Post#2785456
Sorry, the link works fine for me. There are no "interior panels" on these trucks originally. Cameos have door panels the rest have paint.
Monty
Monty's 56 Truck
Avatar is my Truck
unclebrad
unclebrad
Reg: 03-12-19
02-01-20 11:07 AM - Post#2785602
If you are able, I'd love to see pics of your progress.
"55 Cameo w/409
Edited by unclebrad on 02-01-20 11:13 AM. Reason for edit: No reason given.
Vijay
Vijay
Reg: 09-06-04
02-03-20 07:48 PM - Post#2785832
Okay the link worked on my Mac.
I see the hole you drilled. What was next? Fishing up and pop rivetting the plate?
Don57
Don57
Loc: Illinois
Reg: 04-28-00
02-04-20 09:54 AM - Post#2785865
Another option is to drill a couple of small holes above and below the big hole. Fish the plate up and install a bolt in the big hole to hold the plate in place then spot weld the plate at the 2 small holes. Then smooth off the spot welds and the attachment points are invisible. If your interior panels are already finished, I guess rivets would be easier.
1957 3200 Stepside
monty56
monty56
Reg: 04-26-04
02-04-20 10:49 AM - Post#2785870
    In response to Don57
What Don57 describes is what I did. Two 1/4" holes plug welded to the plate.
Monty
Monty's 56 Truck
Avatar is my Truck
Execution time: 0.421 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:29 PM
