Username Post: Misfire        (Topic#359381)
chevyisland
chevyisland
Loc: Trinity, TX
Reg: 07-18-03
01-05-20 10:19 AM - Post#2783748
2011 GMC Sierra 1500 SLE, had friend run his scan tool on it, and it came up cylinder #7 misfire. Any ideas as to the problem? Plugs? Coil? Wire? Any help would be appreciated.
2011 GMC SIERRA SLE 1500
1966 Thunderbird Tudor
Edited by chevyisland on 01-05-20 11:02 AM. Reason for edit: No reason given.
01-05-20 11:34 AM - Post#2783751
    In response to chevyisland
Plug, wire, coil, dead injector, most common possibilities .
chevyisland
chevyisland
Loc: Trinity, TX
Reg: 07-18-03
01-05-20 01:33 PM - Post#2783756
That helps a lot, thanks
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-05-20 04:03 PM - Post#2783767
Try swapping the coil with another cylinder to see if it moves with it.
That would be my first guess.
Old School GM fan FOREVER
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-05-20 07:22 PM - Post#2783777
Cylinder #7 is one of those deactivated by the AFM. One or more of the special AFM lifters may have failed holding valves open or closed.
You might run a compression check on that cylinder to help diagnose if it is a AFM issue.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-06-20 04:20 AM - Post#2783798
    In response to YOUNG57
I have a 13 model in the shop just put the heads back on after replacing all the AFM lifters for the same issue. I will finish the job today.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-06-20 08:46 AM - Post#2783812
    In response to junkman104
You replaced the bad AFM lifters with new ones…
When the 60 month/100k miles warranty on my 2014 Yukon ended last year, I had it reprogramed deactivating the AFM to stop wear and tear on the stupid AFM lifters which start to fail between 100k and 300k miles.
Before I deactivated the AFM I got 17.3 average MPG highway, now I get 19.1, go figure.
If any of my AFM lifters do fail, I will get one of the kits that replaces them, the cam and cover plate that activates them to make it like a pre-2007 LS 5.3.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-06-20 04:16 PM - Post#2783844
I do what the customer wants. Personally I will never own a AFM engine, but would delete it if I did.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-06-20 06:30 PM - Post#2783864
I agree on the AFM cylinder dropout but before confirming that start with easy
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-06-20 07:53 PM - Post#2783871
    In response to rockfangd
A compression check on that cylinder is a cheap and easy way to help diagnose if it is a AFM issue.
Edited by YOUNG57 on 01-06-20 07:55 PM. Reason for edit: No reason given.
Execution time: 0.168 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:55 AM
